Home > General > OEM v's spurious side steps. |
Big ken Member Since: 14 Nov 2011 Location: Airdrie Posts: 282 |
Ebay
Thu Jan 17 2013 6:44am |
Peanut Member Since: 31 Jul 2012 Location: Leicestershire Posts: 110 |
Got mine from -
Thu Jan 17 2013 6:54am |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
I was in the same situation - opted for the cheaper lookalikes - never had a problem - fitted within a couple of hours .If you can afford a little extra I would opt for the versions that come with the PRE CUT sill replacements a little less hassle than cutting your own. 16MY Estoril Blue SVR.............
Thu Jan 17 2013 8:08am |
When you have fitted them make sure you give the aluminium trim a few coats of a good wax, this will stop them from tarnishing. |
Thu Jan 17 2013 8:21am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
That's strong money , try here £149 delivered......but you can make an offer too Edit: I have no link to this advert ON THE WAY: BMW F21 M140i MERCEDES GL350 - Metallic Navy Blue w/Grey interior GOING: BMW F31 335D MSport+ xDrive Touring GONE: Land Rover Discovery 4 HSE - Stornaway Grey w/Black Interior (wish we'd kept it ) GONE: BMW F10 520D MSport - Carbon Black GONE:MY12 RRS SDV6 HSE Sumatra/Ivory/Grand Black Privacy glass |
Thu Jan 17 2013 9:27am |
imb111 Member Since: 30 Nov 2012 Location: UK Posts: 28 |
looking to get the ebay ones aswell, heards lots of good feedback |
Thu Jan 17 2013 2:54pm |
cmcb Member Since: 16 Jan 2013 Location: Edinburgh Posts: 33 |
I got mine from eBay and try are spot on. If you can get a set with pre cut sills as it will save a bit of faffing and effort. They are pretty straight forward to fit too RRS TDV8 HST
Thu Jan 17 2013 10:40pm |
grass cutter Member Since: 13 Jan 2013 Location: manchester Posts: 4 |
Well thanks for making my mind up for me everyone, gonna get the cheapies and wax the ally trim.
Thu Jan 17 2013 11:01pm |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 |
When I purchased my sport it came with OEM steps and they were a bit scruffy so I ordered the eBay replicas to replace them, the eBay ones were exactly the same and I didn't even have to change the brackets as they were identical to the OEM ones so the new steps just slid on, took about half an hour and you would never tell they weren't the original ones |
Thu Jan 17 2013 11:13pm |
+1 for going to apply wax to them, thanks for the tip Ady |
Thu Jan 17 2013 11:15pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1940 |
I know that money is always a sensitive subject (so is everything on here it seems) but am I alone in seeing something strange in being able to afford to buy a RANGE ROVER, then spoiling the originality by buying cheap (many Chinese made) side steps? If the car itself represents so much disposable income that to buy some side steps means cheap facsimile parts, isn't it better to get a cheaper car? To me, a Range Rover would always be worth OEM parts. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Fri Jan 18 2013 2:47am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
A similar thought went through my mind BKHK. These things aren't cheap to run at the best of times so trying to do it "on the cheap" seems a little silly. But some people manage it and good luck to them.
Fri Jan 18 2013 8:19am |
The wax isn't to keep them shiney, infact the aluminium trim isn't shiney at all The wax helps protect the aluminium trim from getting tarnished as said in my previous post. Unprotected aluminium will tarnished and corrode. Its also worth protecting the aluminium rivites that hold the trims on, these have been known to corrode and cause the trim to fall off. |
Fri Jan 18 2013 8:26am |
Ady, just pulling your leg 2012 SDV6 - it's missing a couple of cylinders
Fri Jan 18 2013 9:16am |
