Home > Technical > do tdv6 range rover sports use oil ?
cozzyrick
2008 Range Rover Sport TDV6 SE Stornoway Grey
I have a 2008 tdv6 range rover sport and sent it to the dealer for service in October and noticed engine oil was on minimum on dipstick today. its been 3months since service and lost about 1 litre but is this normal or does it need investigating ? 2008 range rover sport FANTOM styling
stornoway grey
Post #369078 Fri Jan 11 2013 10:47pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
How many miles has it done since it was last serviced? 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #369080 Fri Jan 11 2013 10:54pm
cozzyrick
I would say around 1200 ish miles 2008 range rover sport FANTOM styling
stornoway grey
Post #369083 Fri Jan 11 2013 11:11pm
pedro444
TDV6s with DPFs actually tend to gain oil between services. It's not actually oil but fuel that has found its way to the sump - the regen process injects a bit of extra fuel to get the DPF temperature up (well that's how it works on my Jag XJ and it's the same basic engine - our RRS TDV6 is an early one without a DPF). As a result and to prevent problems with oil levels getting too high between services the engine should be filled only to between min and midway.
Unless of course you checked it just after the last service then bang goes that theory!!
Post #369087 Fri Jan 11 2013 11:37pm
cozzyrick
no its been around 3 months from when it was serviced and I never checked it then as you would of thought it would be bang on coming out of the main dealers. I will keep my eye on it now 2008 range rover sport FANTOM styling
stornoway grey
Post #369088 Fri Jan 11 2013 11:45pm
Not sure the 2008 RRS had DPF fitted. Mine doesn't. 2012 SDV6 - it's missing a couple of cylinders
Post #369096 Sat Jan 12 2013 10:02am
mse
All engines can be expected to use some oil yes. Oil and any reservoir should never be overfilled, but should always be close or at maximum levels, not only does this allow you to use oil without running dry, but operating at certain angles requires a good res balance.
If you get fuel in your oil sump, your about to shagg your engine, engine oil sump is for oil, cleaner the better. Mike
2014 Facelift Discovery
Post #369109 Sat Jan 12 2013 3:30pm
cozzyrick
thanks mse 2008 range rover sport FANTOM styling
stornoway grey
Post #369216 Sun Jan 13 2013 7:13pm
mse
What you need to keep an eye on is excessive use or sudden drops Mike
Post #369233 Sun Jan 13 2013 9:46pm
I would have said a litre in 3 months is quite high?..especially as you've only done 1200 miles....
Are those 1200 miles made up of lots of short trips?
Certainly keep an eye on it... mine drops a litre over 12 months usually, 15k miles. RRS gone
Post #369269 Mon Jan 14 2013 10:28am
Bomber H
I've had my 3.0TDV6 for just over 3 months now, it was serviced before delivery, and I've covered about 1600 miles since then.
I've checked the digital read-out pretty much every week after the 1st month, and its still showing the level as max. 2016 VW Golf GTD DSG
2007 Exige S British GT SE
Gone : 2011 3.0TDV6 HSE, Stornoway Grey, Ivory, Piano Black Trim, Paddleshift, Privacy Glass, Side Steps, Mud Flaps, Heated Steering Wheel, Timed Climate & Remote Park Heating Smile
Post #369454 Tue Jan 15 2013 2:41pm
cozzyrick
yes I will be checking it weekly now for sure and hope every things ok with it 2008 range rover sport FANTOM styling
stornoway grey
Post #369458 Tue Jan 15 2013 3:41pm
