Home > Maintenance & Modifications > Removing the rear door door-card |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9008 |
I was changing the puddle lights in the doors. All went well until the rear left door. As I pulled the lamp out of the door, the wire came loose and flicked back inside the door. I can just feel it with a finger in the aperture so I think I'll need to pull the door-card away at the bottom to be able to get the wire back through the aperture.
Thu Jan 10 2013 11:17pm |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
Hello mate,
Fri Jan 11 2013 12:36am |
Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268 |
Or make a small hook out of some wire and go fishing ! i always keep a metal coathanger int he garage for these occaisions Why?.. Because i can....
Fri Jan 11 2013 10:36am |
Alternatively there are 2 screws that once un-done will allow the whole card to be removed.
Fri Jan 11 2013 11:46am |
Popped out to the vehicle at lunchtime. Used a small knife to lever the bottom corners of the door-card away. 2 clips "popped" and I was able to push the wiring back through the aperture. The wire appears to be shorter on this door than the others for some reason. A gentle but firm push on the panel reconnected the clips and I've got a working light on that door again. Total time: 1 minute.
Fri Jan 11 2013 4:12pm |
Good effort! That's your rear screen demister and puddle lights sorted. You'll be changing your diff/transfer box oils next Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section
Fri Jan 11 2013 4:57pm |
Hmmm, not sure I'd go that far kav!
Fri Jan 11 2013 5:52pm |
