![]() | Home > Faults & Fixes > HELP: Transmission fault messages? |
As daft as it sounds, check your brake light bulbs. |
Mike_C Member Since: 19 Mar 2012 Location: Bucks Posts: 184 ![]() ![]() ![]() |
Really??? Is that a known cause for those particular error messages, or for all sorts of random error messages? - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE) - BMW 330Ci M-Sport coupe - Suzuki GSX-R750 K6 'Stealth' - trackdays and high speed tourer |
Yes |
Thanks Ady, will check!
ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163 ![]() ![]() |
Do they clear after a while.....battery may need a good charge. |
So i'm lead to believe, also check your battery & alternator are in good working order. |
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
Maybe they disturbed or damaged the wiring to the range change motor or the transfer box. Have you had a look?
Apparently it needs a new gearbox ECU - great!! |
gruodiz Member Since: 27 Nov 2011 Location: Klaipeda Posts: 63 ![]() ![]() |
Mike_C how did you solve the problem?
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
Is it possible to have the ECU reflashed by someone with a faultmate? Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section |
I have JLR SDD and already reflashed the module but with no success, just took stop light switch off and see that its burnt a little bit inside, will see what to do.
Ah yes - the stop light switch is another common problem. Hopefully a new one will fix your issue |
imb111 Member Since: 30 Nov 2012 Location: UK Posts: 28 ![]() ![]() |
The specialist wouldn't be the one where the old mini garage was in maidenhead would it?
Finally looks like solved the problem. Firstly changed all back light bulbs to new and good quality, then cleaned the brake pedal switch but these two did no change even after transfer box module reflash, then gearbox module reflash and engine ecu reflash because I had engine light sometimes. The last was transfer box solenoid connection chech and voila |
