Home > Faults & Fixes > HELP: Transmission fault messages?
Mike_C
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Tangiers Orange
Hi all,
I had a small gearbox oil leak from a seal, which has now been replaced. Whilst they were at it, they also replaced the gearbox oil, of course.
However, an error message now appears on the dash - three, actually! These read in the following order, when you start the car:
TRANSMISSION RANGE CHANGE NOT AVAILABLE
SYSTEM FAULT SPECIAL PROGRAMS NOT AVAILABLE
SPECIAL PROGRAMS OFF
The garage thought this might be the contacts on the ECU that needed cleaning (I was doubtful as there were no error messages prior to the leak), they tried this and apparently it worked but when I went to pick the car up the above error messages appeared.
They are a Land Rover specialist but I am starting to loose faith, I think they may be more suited to Defender's and early Disco's than the latest models. The car is a 2005 4.4 V8 RRS.
Anyone got any ideas what could be causing these messages and what the fix is?
Thanks! - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
- BMW 330Ci M-Sport coupe
- Suzuki GSX-R750 K6 'Stealth' - trackdays and high speed tourer
Post #368657 Tue Jan 08 2013 4:12pm
As daft as it sounds, check your brake light bulbs. Thumbs Up
Post #368663 Tue Jan 08 2013 4:32pm
Mike_C
Really??? Is that a known cause for those particular error messages, or for all sorts of random error messages? - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
Post #368665 Tue Jan 08 2013 4:49pm
Yes Shocked it has been known many times before.
Post #368681 Tue Jan 08 2013 6:34pm
Mike_C
Thanks Ady, will check!
Do the brake lights cause those specific fault codes? Who is it any random error
Message? - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
Post #368683 Tue Jan 08 2013 6:57pm
ELD70
Do they clear after a while.....battery may need a good charge.
Post #368686 Tue Jan 08 2013 7:23pm
Message?
So i'm lead to believe, also check your battery & alternator are in good working order.
Post #368696 Tue Jan 08 2013 8:49pm
Bob.
Maybe they disturbed or damaged the wiring to the range change motor or the transfer box. Have you had a look?
Post #368710 Tue Jan 08 2013 11:29pm
Mike_C
Apparently it needs a new gearbox ECU - great!! Rolling Eyes - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
Post #368871 Thu Jan 10 2013 2:05pm
gruodiz
Lithuania
Mike_C how did you solve the problem?
I have the same problem
Post #370701 Wed Jan 23 2013 6:49pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Is it possible to have the ECU reflashed by someone with a faultmate? Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
http://rrsport.co.uk/forum/topic28424.html
Post #370704 Wed Jan 23 2013 7:07pm
gruodiz
Lithuania
I have JLR SDD and already reflashed the module but with no success, just took stop light switch off and see that its burnt a little bit inside, will see what to do.
will post some pics later
Post #370709 Wed Jan 23 2013 7:17pm
kav1187
Ah yes - the stop light switch is another common problem. Hopefully a new one will fix your issue Thumbs Up Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
Post #370712 Wed Jan 23 2013 7:39pm
imb111
2010 Range Rover Sport TDV8 HSE Java Black
The specialist wouldn't be the one where the old mini garage was in maidenhead would it?
If it is then yes they do seem to have loads of old school stuff there...guess I will have to take my RR elsewhere after reading this!
Post #370714 Wed Jan 23 2013 8:50pm
gruodiz
Lithuania
Finally looks like solved the problem. Firstly changed all back light bulbs to new and good quality, then cleaned the brake pedal switch but these two did no change even after transfer box module reflash, then gearbox module reflash and engine ecu reflash because I had engine light sometimes. The last was transfer box solenoid connection chech and voila Thumbs Up It looked very nice from outside even from the inside, but reconnection helped.
I did absolute possition sensor reset and transer box calibration programs with no errors so didn't think that any components was fault.
Drove the car in all programs in high and low ranges and in all suspension heights for almost 2kms in closed parking place with no fault codes.
I can say it solved
Post #370886 Thu Jan 24 2013 10:24pm
