Home > General > Transmission problem MY12.... I think
andman
Andorra 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Anybody else had this......
Whilst driving the car seems to pull back and slow down as if the brake has been gently pressed......
At idle and in drive it doesnt roll forward gently as it should......
Usually a quick shift into neutral.... or stop start resolves it......
Im guessing its a common problem....
Thx guys 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
2013 Porsche Boxster S 3.4
2014 Audi A3 S line Quattro
Post #368511 Sun Jan 06 2013 8:48am
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Sounds like a sticky caliper to me. The stop start probably gives it the extra nudge to release the disc from the pads. Check your calipers aren't sticking first Thumbs Up
Post #368520 Sun Jan 06 2013 11:07am
When my car was in for it's 1 yr service, I was told that 3 gearbox software updates had been applied to correct various issues (one being as you described).
Could be worth checking with the dealer if yours needs it doing Thumbs Up ON THE WAY: BMW F21 M140i
Post #368524 Sun Jan 06 2013 12:40pm
kav1187
Wow! 3 updates in a MY12 car??? You'd think they'd have figured it out by now!
Post #368525 Sun Jan 06 2013 12:45pm
andman
Thanks guys..... I will go into the stealers and ask them to check both
it happens very randomly... so im curious to find out 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Post #368528 Sun Jan 06 2013 1:09pm
Disco_Mikey
You think they would have figured it out with the thousands and thousands of miles of testing, before the car is released Rolling Eyes
Post #368532 Sun Jan 06 2013 3:25pm
mse
Anyone that thinks there isn't constant design, manufacture and performance changes between model years is a fool...not to mention the many different things that are picked up in the real world!! Mike
2014 Facelift Discovery
Post #368547 Sun Jan 06 2013 7:18pm
Agreed Mike, my only gripe was that I had to chase on these via reporting the problem (different to the above) rather than them being told to me as they found cures/improved the workings. Smile ON THE WAY: BMW F21 M140i
Post #368552 Sun Jan 06 2013 7:45pm
