![]() | Home > General > Transmission problem MY12.... I think |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
Sounds like a sticky caliper to me. The stop start probably gives it the extra nudge to release the disc from the pads. Check your calipers aren't sticking first |
When my car was in for it's 1 yr service, I was told that 3 gearbox software updates had been applied to correct various issues (one being as you described).
Wow! 3 updates in a MY12 car??? You'd think they'd have figured it out by now! |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 ![]() ![]() ![]() |
Thanks guys..... I will go into the stealers and ask them to check both
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4453 ![]() ![]() ![]() |
You think they would have figured it out with the thousands and thousands of miles of testing, before the car is released ![]() |
Anyone that thinks there isn't constant design, manufacture and performance changes between model years is a fool...not to mention the many different things that are picked up in the real world!! Mike
Agreed Mike, my only gripe was that I had to chase on these via reporting the problem (different to the above) rather than them being told to me as they found cures/improved the workings. |
