Home > Maintenance & Modifications > De-Tango'd. colour coordinated, and LEDs installed
Page 6 of 7 <1234567>
V88ABA
2007 Range Rover Sport Supercharged Java Black
Fingers crossed I'll get the second done today. Opted for the oven method. 130 for 10 mins. Checked after 5 and was far too hot!! The underside of the casing Was far too soft from sitting on the bottom of the oven however the mastic wasn't sticky enough. Decided to use a towel, this then burnt.. The wife was not happy.. Turned out to be her favourite dior towel :/
Any fellow "bakers" have any tips?
Post #353559 Mon Aug 13 2012 9:01am
Yeah - buy cheaper towels! Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #353584 Mon Aug 13 2012 11:30am
IMMensaMind
United States 2006 Range Rover Sport Supercharged Chawton White
I would slightly dampen the towel - I burnt up a towel screwing this up initially as well! Laughing
As for awdman's slightly larger left-side HALO...
It looks like this emoticon:
Laughing
Post #356567 Fri Sep 14 2012 3:29pm
V88ABA
I'm sorry if its been asked but what did you use to fix halos to the lights? Thanks
Post #367214 Thu Dec 20 2012 1:21pm
2 pack epoxy.
It's heat resistant, and holds well... RRS gone
Post #367216 Thu Dec 20 2012 1:25pm
IMMensaMind
+2 on the epoxy. Get the two cylinder plunger plastic epoxy - clear. Treat the reflective coating like a very fragile foil; it delaminates extremely easily. Dry fit first, then put tiny dots of the epoxy exactly where the rings will push over to conceal. I put 6 dots total and they're still holding.
Post #367239 Thu Dec 20 2012 4:48pm
V88ABA
Thanks guys. Halos arrived today. Less than 24hrs after I purchased them! Now when to tackle this beast hmmmn
Post #367300 Fri Dec 21 2012 11:56am
One word of caution
When using the heat gun method, be careful not to overheat, the glue really does not need much to get it tacky... too much heat makes the lens plastic brittle Thumbs Up RRS gone
Post #367301 Fri Dec 21 2012 11:59am
V88ABA
Thanks for the tip, I won't lie.. I'm dreading it.
Post #367304 Fri Dec 21 2012 12:04pm
Patience is the key Thumbs Up
and thermal fingers.... Mr. Green RRS gone
Post #367306 Fri Dec 21 2012 12:08pm
V88ABA
When it comes to wiring these up. Am I right in thinking if the halos are on whilst main lights are in this is actually illegal???
Post #367500 Sun Dec 23 2012 3:03pm
sparky8181
Have a look at this
http://assets.dft.gov.uk/publications/dft-...lights.pdf
Post #367503 Sun Dec 23 2012 3:39pm
V88ABA
Thank you! I think ill just get them connected to the sides. Police round here seem very lenient.
Post #367513 Sun Dec 23 2012 7:25pm
sparky8181
I maybe wrong but I'm sure they stay on even with normal headlights on anyway on the newer models, but not sure if its at a reduced brightness.
Maybe someone with a my10 onwards could confirm?
Post #367522 Sun Dec 23 2012 8:40pm
mse
The signature light are on all the time as sidelights Mike
2014 Facelift Discovery
Post #367544 Mon Dec 24 2012 12:44am
