![]() | Home > Maintenance & Modifications > De-Tango'd. colour coordinated, and LEDs installed |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
Yeah - buy cheaper towels! ![]() 2008 TDV8 - it was a labour of love and is much missed |
IMMensaMind Member Since: 13 Apr 2007 Location: Wisconsin Posts: 57 ![]() ![]() ![]() |
I would slightly dampen the towel - I burnt up a towel screwing this up initially as well! |
V88ABA Member Since: 01 May 2012 Location: northampton Posts: 338 ![]() ![]() |
I'm sorry if its been asked but what did you use to fix halos to the lights? Thanks |
2 pack epoxy.
+2 on the epoxy. Get the two cylinder plunger plastic epoxy - clear. Treat the reflective coating like a very fragile foil; it delaminates extremely easily. Dry fit first, then put tiny dots of the epoxy exactly where the rings will push over to conceal. I put 6 dots total and they're still holding. |
Thanks guys. Halos arrived today. Less than 24hrs after I purchased them! Now when to tackle this beast hmmmn |
Thanks for the tip, I won't lie.. I'm dreading it. |
Patience is the key |
When it comes to wiring these up. Am I right in thinking if the halos are on whilst main lights are in this is actually illegal??? |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 ![]() ![]() |
Have a look at this
Thank you! I think ill just get them connected to the sides. Police round here seem very lenient. |
I maybe wrong but I'm sure they stay on even with normal headlights on anyway on the newer models, but not sure if its at a reduced brightness.
The signature light are on all the time as sidelights Mike
