Home > Maintenance & Modifications > De-Tango'd. colour coordinated, and LEDs installed
Page 2 of 7 <1234567>
Sorry forgot to say.
They are high powered Um-nitza Orion V2's
120mm rings RRS gone
Post #334108 Mon Feb 27 2012 1:33pm
scott7
Scotland
Nice job, where did you get the clear replacement reflectors?.
Post #334128 Mon Feb 27 2012 3:44pm
http://www.rrsport.co.uk/forum/topic22760.html
Post #334130 Mon Feb 27 2012 3:47pm
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
Great job man! Vadim A.
Post #334142 Mon Feb 27 2012 6:29pm
sam006
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Looks very smart, top job Range Rover Sport HSE and for a bit of weekend fun a S1 Lotus Elise with a few track biased additions!
Post #334182 Tue Feb 28 2012 12:01am
Thanks guys Thumbs Up
Have had a bit of a mare since yesterday Censored
One of the LED rings wasn't stuck on very well and as a result I've got to re-split that headlight to re-attach it... Censored
AND
Currently the other headlight LEDs are refusing to power up.... I'm hoping it's a connection issue with the last Y cable because it's both rings not just the one... so I've got some investigation work to do... Big Cry
Saying that the working side (with it's slipped led ring) looks great! Rolling with laughter RRS gone
Post #334194 Tue Feb 28 2012 9:33am
That's a shame awd man, hopefully, it'll be a quick fix.
I feel we need to see a pic of the slipped LED, just for research purposes of course Whistle Laughing ON THE WAY: BMW F21 M140i
Post #334195 Tue Feb 28 2012 9:45am
will do Bean Thumbs Up
I've managed to forget my i-phone but can get it lunchtime so you'll have to wait till then Whistle RRS gone
Post #334197 Tue Feb 28 2012 9:51am
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
AWD, looks very nice!
Good job!
Question about the reassamblimg:
Reheating is just enough, or do you have to remove the old kit and apply new glue?
How do you manage the unit to be water tight again?
Thumbs Up SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #334213 Tue Feb 28 2012 11:14am
Re-heating is actually enough, the glue/mastic goes from solid to very sticky again quite happily, but on the lower edges I re-sealed with black sealant just as an extra Thumbs Up RRS gone
Post #334214 Tue Feb 28 2012 11:27am
Tim Hoang
Hi AWD,
Just wondering how you connect these LED to ie. to side light / main light / DRL ???
Thanks 2005 RRS TDV6 HSE Java Black
2005 997 C2
Post #334219 Tue Feb 28 2012 12:45pm
They are wired up as DRL's Thumbs Up
The kit comes with 2 trigger wires, relay & full loom.
They can be set up to come on with side lights, or as DRL's or even fade up and down with internal lights! RRS gone
Post #334220 Tue Feb 28 2012 12:56pm
awd man wrote:
................. or even fade up and down with internal lights!
Why would you do that though Confused
Wired as DRL's the way you've done is the best I'd say. Thumbs Up ON THE WAY: BMW F21 M140i
Post #334223 Tue Feb 28 2012 1:05pm
Sorry..should have been clearer
They can be wired with the 2nd trigger, to fade up when you unlock the car (with the internal lights) and then stay on once the ignition is turned on (primary trigger)..then stay on after you've turned the engine off at your destination.. and fade down once you've exited the vehicle after locking (using the internal lights again)
Which is all pretty cool... but I wasn't going to let the electrician start running feeds from the internal light feed... so stuck with good old DRLs "on and off with the ignition" RRS gone
Post #334224 Tue Feb 28 2012 1:07pm
Ah, I understand now, thought you were implying you could have a mobile disco look with mood lighting Laughing
You could have got your spark to wire up courtesy lights in the back when he was in there though, given LR see no need for them and only think the ability to read maps/books is required Banging Head Whistle ON THE WAY: BMW F21 M140i
Post #334227 Tue Feb 28 2012 1:27pm
