Home > Maintenance & Modifications > Rear DVD Headreat Monitor Trim Removal |
Just pull the trim out...
Thu Mar 03 2011 6:04am |
garthbo Member Since: 02 Mar 2011 Location: Manila, Philippines Posts: 4 |
Thanks Bobby! Would you advise to start from the bottom up or top to bottom? |
Thu Mar 03 2011 6:17am |
I have not done it but I would think pulling out each corner a little and slowly would be ideal. Malaysia Boleh!
Thu Mar 03 2011 6:46am |
Okay I've pulled out the bottom part and both sides but can't seem to detach the upper portion. I've tried pulling in every direction imaginable and any more force would I think break the trim already. Any suggestions?
Mon Mar 07 2011 12:30pm |
beany Member Since: 13 Dec 2012 Location: derbyshire Posts: 1 |
i have the same problem, did you manage to remove the trim in the end, if so how?
Thu Dec 13 2012 12:45am |
