Home > Maintenance & Modifications > Rear DVD Headreat Monitor Trim Removal
garthbo
2008 Range Rover Sport Supercharged HST Java Black
Hello All. I have some scratches on the outer plastic/rubber trim of the DVD Monitor on the front headrest. I wish to have this repainted and was wondering if there's a way to remove these trim pieces. If not, is it possible to pull out the headrest so I can work on painting outside the vehicle? I'm assuming that there will be wires connected so this maybe difficult to remove. Painting inside the car may not be a good idea so if there's a way I can remove the trim pieces or the entire headrest, this will be easier and cleaner to do.
Thanks!
Post #290827 Wed Mar 02 2011 7:04am
Bobby
Just pull the trim out...
...carefully. Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #290933 Thu Mar 03 2011 6:04am
garthbo
Thanks Bobby! Would you advise to start from the bottom up or top to bottom?
Post #290934 Thu Mar 03 2011 6:17am
Bobby
I have not done it but I would think pulling out each corner a little and slowly would be ideal. Smile Malaysia Boleh!
Post #290938 Thu Mar 03 2011 6:46am
garthbo
Okay I've pulled out the bottom part and both sides but can't seem to detach the upper portion. I've tried pulling in every direction imaginable and any more force would I think break the trim already. Any suggestions?
Thanks..
Post #291364 Mon Mar 07 2011 12:30pm
beany
i have the same problem, did you manage to remove the trim in the end, if so how?
cheers bean Very Happy
Post #366469 Thu Dec 13 2012 12:45am
