![]() | Home > Maintenance & Modifications > Rear DVD Headreat Monitor Trim Removal |
Just pull the trim out...
garthbo Member Since: 02 Mar 2011 Location: Manila, Philippines Posts: 4 ![]() ![]() |
Thanks Bobby! Would you advise to start from the bottom up or top to bottom? |
I have not done it but I would think pulling out each corner a little and slowly would be ideal. |
Okay I've pulled out the bottom part and both sides but can't seem to detach the upper portion. I've tried pulling in every direction imaginable and any more force would I think break the trim already. Any suggestions?
beany Member Since: 13 Dec 2012 Location: derbyshire Posts: 1 ![]() ![]() |
i have the same problem, did you manage to remove the trim in the end, if so how?
