Home > General > Jack |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
What about something like this ON THE WAY: BMW F21 M140i
Wed Dec 12 2012 4:49pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
I was hoping that someone had found a trolly jack that would fit, the standard scissor jack is a very poor offer, maybe the older type bottle Jacks that Land Rover use to fit as standard would be a good option. Use to have one under bonnet in a D2 I use to run, only ever used it once, very stable with a good lifting height. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Wed Dec 12 2012 5:09pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8988 |
I have used the standard scissor jack once. It was ok and no worse than any other versions of the type that I've used over the years - the biggest issue was the handle which was pretty rubbish.
Wed Dec 12 2012 5:13pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
I have the a small bottle jack and modified to suit lump of wood under back seat wrapped in a sheet of foam. Fits fine, and foam handy to save suit trousers from interface with muddy verge. The jack came from an old shape L200 Itchypussy. Plenty in scrap yards and because they are hidden behind rear seats and bulkhead often missed. The wheel brace that comes with it is more substantial than the bacofoil land rover option. Other alternative is to buy a rescue/recovery membership and just stay warm while Opo changes wheel 2x TDV6. SE and HSE. Both returned to sender with issues👀
Wed Dec 12 2012 5:31pm |
mike21 Member Since: 07 Feb 2011 Location: Essex Posts: 297 |
I recently used the standard scissor jack to change the wheel, no problem but the wheel brace didn't seem sturdy enough to me so I used a more substantial aftermarket wheel brace and now keep it in the boot just in case 2019 BMW X3 2.0i M Sport in metalic black- Brilliant
Wed Dec 12 2012 7:22pm |
I'm a man. Unless it's on the side of a motorway in the dark, I'm changing my own wheel thanks. Waiting a couple of hours for someone to turn up to do it isn't on the agenda. Now, if there's a horse trailer involved as well then I can see the benefit of someone else being involved, but for a car tyre? 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Dec 13 2012 12:42am |
Oh, somebody is tired! I agree, I would at least attempt to change wheel. And bottle jack is fine on horse box, although make note, you need a separate wheel brace as LR one is too big for Ifor Williams wheel nuts 2x TDV6. SE and HSE. Both returned to sender with issues👀
Thu Dec 13 2012 9:03am |
range17 Member Since: 08 Oct 2012 Location: bedford Posts: 109 |
I am still looking for a bottle jack that fits in the cut out in the tool tray ,not found one with enough lift yet zx12r
Thu Dec 13 2012 10:07am |
LAND ROVER BOTTLE JACK KAJ500150 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
Thu Dec 13 2012 10:18am |
How often do you guys get puncher's Ive only had one in errr a lot of years driving and many of hunders of thousands of miles, i'd just let recovery deal with it, even if they do take a few hours to arrive, i can always watch my telly till they do. |
Thu Dec 13 2012 10:33am |
^^^ this ON THE WAY: BMW F21 M140i
Thu Dec 13 2012 10:41am |
@ady
Thu Dec 13 2012 11:29am |
Well spotted, so you didn't need a jack either, but i guess it could of been a different story if your tyre had of lost pressure, ie, on the way to the airport etc. I know some will say they have had several puncher's in as many weeks, i think its the luck of the draw. Fail to prepare, prepare to fail springs to mind. |
Thu Dec 13 2012 11:34am |
I carry an air pump in the boot most of the time which is useful for those slow punctures caused by a screw/nail that's still in the tyre. Sometimes that's enough to get you to a tyre place without having to get dirty or wait for a recovery van
Thu Dec 13 2012 11:41am |
