Home > General > Jack
Page 2 of 3 <123>
1st sensible answer
would a air jack (those bags you blow up with the car exhaust) fit when deflated
Post #366423 Wed Dec 12 2012 5:46pm
What about something like this Question ON THE WAY: BMW F21 M140i
Post #366425 Wed Dec 12 2012 5:49pm
SRE
Spain
I was hoping that someone had found a trolly jack that would fit, the standard scissor jack is a very poor offer, maybe the older type bottle Jacks that Land Rover use to fit as standard would be a good option. Use to have one under bonnet in a D2 I use to run, only ever used it once, very stable with a good lifting height. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #366426 Wed Dec 12 2012 6:09pm
I have used the standard scissor jack once. It was ok and no worse than any other versions of the type that I've used over the years - the biggest issue was the handle which was pretty rubbish.
The only issue with a bottle jack is the small lifting head. There was a thread earlier this year offering an adaptor plate to fit in to the jack locating hole in the chassis. Should be easy enough to get one made up if required. 2012 SDV6 - it's missing a couple of cylinders
Post #366427 Wed Dec 12 2012 6:13pm
simple1
I have the a small bottle jack and modified to suit lump of wood under back seat wrapped in a sheet of foam. Fits fine, and foam handy to save suit trousers from interface with muddy verge. The jack came from an old shape L200 Itchypussy. Plenty in scrap yards and because they are hidden behind rear seats and bulkhead often missed. The wheel brace that comes with it is more substantial than the bacofoil land rover option. Other alternative is to buy a rescue/recovery membership and just stay warm while Opo changes wheel Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #366429 Wed Dec 12 2012 6:31pm
mike21
2009 Range Rover Sport TDV6 HSE Stornoway Grey
I recently used the standard scissor jack to change the wheel, no problem but the wheel brace didn't seem sturdy enough to me so I used a more substantial aftermarket wheel brace and now keep it in the boot just in case Thumbs Up 2019 BMW X3 2.0i M Sport in metalic black- Brilliant
2014 Mitsubishi Outlander PHEV Atlantic Grey, replaced with 2018 Frost White Outlander PHEV, can't fault em - now gone
2012 SDV6 HSE in Orkney Grey, Privacy Glass & Side Steps (notice a theme)! - Even better but now gone
2009 TDV6 HSE in Stornoway Grey, 20" alloys, Privacy Glass & Side Steps - Fantastic! but gone
Post #366436 Wed Dec 12 2012 8:22pm
I'm a man. Unless it's on the side of a motorway in the dark, I'm changing my own wheel thanks. Waiting a couple of hours for someone to turn up to do it isn't on the agenda. Now, if there's a horse trailer involved as well then I can see the benefit of someone else being involved, but for a car tyre? 2012 SDV6 - it's missing a couple of cylinders
Post #366466 Thu Dec 13 2012 1:42am
simple1
Oh, somebody is tired! I agree, I would at least attempt to change wheel. And bottle jack is fine on horse box, although make note, you need a separate wheel brace as LR one is too big for Ifor Williams wheel nuts Rolling with laughter 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #366477 Thu Dec 13 2012 10:03am
range17
I am still looking for a bottle jack that fits in the cut out in the tool tray ,not found one with enough lift yet Sad zx12r
bmw gs1200 adventure
defender 90 off roader
Post #366483 Thu Dec 13 2012 11:07am
SRE
Spain
Google
LAND ROVER BOTTLE JACK KAJ500150 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #366484 Thu Dec 13 2012 11:18am
How often do you guys get puncher's Question Ive only had one in errr a lot of years driving and many of hunders of thousands of miles, i'd just let recovery deal with it, even if they do take a few hours to arrive, i can always watch my telly till they do. Thumbs Up
Post #366488 Thu Dec 13 2012 11:33am
^^^ this Thumbs Up ON THE WAY: BMW F21 M140i
Post #366490 Thu Dec 13 2012 11:41am
@ady
I did notice a screw in one of my front tyres recently - only noticed because the vehicle was sat with some steering lock applied. Luckily it was holding air and I managed to drive to my usual tyre place and have it repaired. 2012 SDV6 - it's missing a couple of cylinders
Post #366499 Thu Dec 13 2012 12:29pm
Well spotted, so you didn't need a jack either, but i guess it could of been a different story if your tyre had of lost pressure, ie, on the way to the airport etc. Thumbs Up I know some will say they have had several puncher's in as many weeks, i think its the luck of the draw. Fail to prepare, prepare to fail springs to mind. Big Cry
Post #366502 Thu Dec 13 2012 12:34pm
I carry an air pump in the boot most of the time which is useful for those slow punctures caused by a screw/nail that's still in the tyre. Sometimes that's enough to get you to a tyre place without having to get dirty or wait for a recovery van Thumbs Up
I don't wash/polish the car very often but I do fluid and tyre checks pretty frequently and always before a long trip. 2012 SDV6 - it's missing a couple of cylinders
Post #366503 Thu Dec 13 2012 12:41pm
Page 2 of 3 <123>
