![]() | Home > Maintenance & Modifications > drivers door lock sticking |
Its a common problem on the 2006 model cars, a dealer will be about £130-£150 to fix, but your passanger door won't be too far behind going the same way which is more difficult to repair and more costly unless you have a good warranty |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
^^^Because thats the one with the emergency key lock and there is more involved. |
mark hamster Member Since: 26 Nov 2011 Location: nottingham Posts: 116 ![]() ![]() ![]() |
thanks for tip ady,works well.! more info on this common problen them.? |
Benidorm Mick Member Since: 27 May 2010 Location: Wiltshire Posts: 102 ![]() ![]() |
Got the same problem guys. is this something my local man can fix or is it a LR job? What part is it that goes wrong??? Thanks |
ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163 ![]() ![]() |
Disco 3 forum has the walkthrough guide for this problem. |
Mick, if your car has got a warranty in place then it should be covered |
Quote from stealers £160 inc. £49 for the part and 1 hour labour. can only assume it's a 2 man job at some point otherwise that would be £110 an hour labour |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
What part is it as my car has started playing up |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
How to replace RHS door latch and/or window regulator (Door doesn't lock/unlock)
Thanks |
No worries - just double check the part numbers as the guides are for the disco3. |
god can not believe i started this topic in april god where does time go.? when i had my problem,somebody on another topic said just leave it and it will start to work again,and guess what |
