Home > Maintenance & Modifications > drivers door lock sticking
mark hamster
help please,last night the wife noticed that when she got out car and locked doors with key fob that the drivers door not locking.when home, i got inside and pressed the unlock and lock buttons on dash and what seems to happen is that the little lever under the inside door handle only seems to move about half way.? gave the lock a spray of wd 40 last night but still no joy Big Cry had aa out and they dont take panels off doors but did make make feel silly as what we can do untill gettng it fixed is close the drivers door and go in from passenger side and push lever in and then lock and all doors locked.! been in car park all day with drivers door not locked and god know's how long its been like this Question Question answers on a postcard to ...... .... lol so any ideas and anybody recommend a good garage nottingham or derby that could fix this please,thanks Mark
Post #340215 Tue Apr 17 2012 6:30pm
Its a common problem on the 2006 model cars, a dealer will be about £130-£150 to fix, but your passanger door won't be too far behind going the same way which is more difficult to repair and more costly unless you have a good warranty Shocked You can lock the drivers door by way of pulling the door handle out on the outside of the car before you shut the door, at the same time as pushing the lock lever on the inside of the car then let go of the door handle and shut your door then press your remote as usual to lock the rest of the car Thumbs Up then check to see if your drivers door has locked, it might take a few goes to master the technique Thumbs Up
Post #340219 Tue Apr 17 2012 6:42pm
shakeapaw
Question why would the passenger side be harder and more expensive to fix Shocked 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #340248 Tue Apr 17 2012 11:12pm
^^^Because thats the one with the emergency key lock and there is more involved. Thumbs Up
Post #340264 Wed Apr 18 2012 7:02am
mark hamster
thanks for tip ady,works well.! more info on this common problen them.?
Post #340322 Wed Apr 18 2012 11:42am
Post #340325 Wed Apr 18 2012 11:54am
Benidorm Mick
2008 Range Rover Sport TDV8 HSE Stornoway Grey
Got the same problem guys. is this something my local man can fix or is it a LR job? What part is it that goes wrong??? Thanks
Post #343291 Fri May 11 2012 12:02pm
ELD70
Disco 3 forum has the walkthrough guide for this problem.
Post #343315 Fri May 11 2012 4:10pm
Mick, if your car has got a warranty in place then it should be covered Thumbs Up If not, then its a job any garage will do for you but better a garage who has done them before then they arn't running away with the hourly labour charge Wink I think a dealer will charge around £120-130ish fitted.
Post #343327 Fri May 11 2012 4:55pm
Benidorm Mick
Quote from stealers £160 inc. £49 for the part and 1 hour labour. can only assume it's a 2 man job at some point otherwise that would be £110 an hour labour Shocked
Reckon my local guy would be delving into the unknown so maybe false economy going there!!
Oh!! And passenger sides gone now Big Cry
Post #344601 Thu May 24 2012 7:38am
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
What part is it as my car has started playing up
Post #366296 Tue Dec 11 2012 8:41pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
How to replace RHS door latch and/or window regulator (Door doesn't lock/unlock)
http://disco3.co.uk/forum/topic33743.html?...lock%5C%22
How to replace rear door latch (check part numbers for RRS)
http://www.disco3.co.uk/wiki/Rear_Door_Latch_Replacement
Both links have been added to the 'definitive list of How To's' in the technical section. Thumbs Up
Post #366302 Tue Dec 11 2012 9:40pm
ShooterNeil
Thanks
Post #366304 Tue Dec 11 2012 10:07pm
kav1187
No worries - just double check the part numbers as the guides are for the disco3.
Post #366305 Tue Dec 11 2012 10:11pm
mark hamster
god can not believe i started this topic in april god where does time go.? when i had my problem,somebody on another topic said just leave it and it will start to work again,and guess what Question its started working again and had no problems since Thumbs Up
Post #366314 Tue Dec 11 2012 10:33pm
