Home > Maintenance & Modifications > Really Need Advice On 2012 Autobiography Conversion
Scotty.J
Scotland
Hi all,
I'm really hoping someone can help me ...
Just about completed putting a genuine 2012 conversion kit on my 2005 Sport, the last job to tick off the list is fixing the quick indication you get from changing the lights.
I went to my local auto electrics specialist and they told me you need to get some resistor to wire in to solve the problem. I am wondering whether or nor these will solve the problem for both front and back lights? :-
http://www.ebay.co.uk/itm/360449150191?ssP...1438.l2649
I have the genuine Land Rover LED 2012 lights.
Any advise / comments are much appreciated!
Thanks
Scott
Post #365444 Tue Dec 04 2012 5:31pm
Sorry, can't help re the electrics at all, but would be impressed to see your powered boot conversion Razz Thumbs Up ON THE WAY: BMW F21 M140i
Post #365445 Tue Dec 04 2012 5:36pm
Scotty.J
Scotland
Are you challenging me? Laughing
I just couldn't justify a new one at the moment so I thought I'd cheat Thumbs Up
Will post some pictures up when its finished.
Post #365449 Tue Dec 04 2012 5:45pm
I don't know if they are the right ohms or watts to fix your problem but i thought it was only the indicators on the dash that flashed too quickly and not the front and rear lights Confused If they are the right resistors then yes they will cure your problem, someone with a bit more tech knowledge will be along soon to advise. Looking forward to the pictures. Thumbs Up
Post #365471 Tue Dec 04 2012 8:22pm
Scotty.J
Scotland
Hi Andy,
Thanks for the advice.
That's right its just the indicators on the dash that are going mental, from outside they flash at the correct speed. Reading back my original I didn't explain that very well Embarassed
Hopefully someone can confirm if they are the right ones and as soon as its all finished pictures will be posted Thumbs Up
Post #365477 Tue Dec 04 2012 9:10pm
moparmuff
England 2008 Range Rover Sport Supercharged HST Java Black
Hi, yes they are the correct resistors to stop the indicators going mental I fitted them to mine when I upgraded my rears to LED Thumbs Up
Post #365499 Wed Dec 05 2012 6:45am
Scotty.J
Scotland
Spot on I'll get them order now.
Thank you! Bow down
Post #365506 Wed Dec 05 2012 10:04am
Scotty.J
Scotland
Just took the resistors to an auto electrics place and unfortunately they wont work! Sad
They stopped my indicators working ... please help!
Post #365858 Sat Dec 08 2012 1:15pm
I don't want to state the obvious but it sounds like they havn't wired the resistors to the lights correctly Confused
Post #365864 Sat Dec 08 2012 2:26pm
See if this topic helps.....
http://www.rrsport.co.uk/forum/topic27527....+resistors
Post #365866 Sat Dec 08 2012 2:36pm
moparmuff
Ady spot on that is the guide I followed when I fitted mine works perfect
Scotty if the indicators don't work I suggest they have wired it wrong Whistle
Post #365867 Sat Dec 08 2012 2:42pm
Scotty.J
Scotland
Thanks for the comments guys.
I took it to an auto electrician who told me it wouldnt work? But thanks alot for the above how to guide I'm going to try the rear lights tomorrow.
Does anyone know how to do the front headlights? or is it just the same as the rears?
Post #365869 Sat Dec 08 2012 3:52pm
moparmuff
Are you looking at these for the front ?
http://www.ebay.co.uk/itm/310473598721?ssP...1438.l2649
Post #365880 Sat Dec 08 2012 5:20pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Front lights go straight on, pm me if you want a set.
Post #365917 Sat Dec 08 2012 8:29pm
Scotty.J
Scotland
You were spot on guys thanks alot for the help! Got it sorted earlier today.
Keep an eye out for finished photos Thumbs Up
Post #366205 Mon Dec 10 2012 10:58pm
