![]() | Home > Maintenance & Modifications > Really Need Advice On 2012 Autobiography Conversion |
Scotty.J Member Since: 25 Apr 2012 Location: Edinburgh Posts: 17 ![]() ![]() |
Hi all,
Are you challenging me? ![]() I just couldn't justify a new one at the moment so I thought I'd cheat ![]() Will post some pictures up when its finished. |
I don't know if they are the right ohms or watts to fix your problem but i thought it was only the indicators on the dash that flashed too quickly and not the front and rear lights |
Hi Andy,
moparmuff Member Since: 25 May 2012 Location: S. Bucks Posts: 96 ![]() ![]() ![]() |
Hi, yes they are the correct resistors to stop the indicators going mental I fitted them to mine when I upgraded my rears to LED |
Spot on I'll get them order now. Thank you! ![]() |
Just took the resistors to an auto electrics place and unfortunately they wont work! |
I don't want to state the obvious but it sounds like they havn't wired the resistors to the lights correctly |
See if this topic helps.....
Ady spot on that is the guide I followed when I fitted mine works perfect
Thanks for the comments guys.
Are you looking at these for the front ?
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
Front lights go straight on, pm me if you want a set. |
You were spot on guys thanks alot for the help! Got it sorted earlier today.
