Home > Maintenance & Modifications > Really Need Advice On 2012 Autobiography Conversion |
Scotty.J Member Since: 25 Apr 2012 Location: Edinburgh Posts: 17 |
Hi all,
Tue Dec 04 2012 5:31pm |
Are you challenging me? I just couldn't justify a new one at the moment so I thought I'd cheat Will post some pictures up when its finished. |
Tue Dec 04 2012 5:45pm |
I don't know if they are the right ohms or watts to fix your problem but i thought it was only the indicators on the dash that flashed too quickly and not the front and rear lights If they are the right resistors then yes they will cure your problem, someone with a bit more tech knowledge will be along soon to advise. Looking forward to the pictures. |
Tue Dec 04 2012 8:22pm |
Hi Andy,
Tue Dec 04 2012 9:10pm |
moparmuff Member Since: 25 May 2012 Location: S. Bucks Posts: 96 |
Hi, yes they are the correct resistors to stop the indicators going mental I fitted them to mine when I upgraded my rears to LED |
Wed Dec 05 2012 6:45am |
Spot on I'll get them order now. Thank you! |
Wed Dec 05 2012 10:04am |
Just took the resistors to an auto electrics place and unfortunately they wont work!
Sat Dec 08 2012 1:15pm |
I don't want to state the obvious but it sounds like they havn't wired the resistors to the lights correctly |
Sat Dec 08 2012 2:26pm |
See if this topic helps.....
Sat Dec 08 2012 2:36pm |
Ady spot on that is the guide I followed when I fitted mine works perfect
Sat Dec 08 2012 2:42pm |
Thanks for the comments guys.
Sat Dec 08 2012 3:52pm |
Are you looking at these for the front ?
Sat Dec 08 2012 5:20pm |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
Front lights go straight on, pm me if you want a set. |
Sat Dec 08 2012 8:29pm |
You were spot on guys thanks alot for the help! Got it sorted earlier today.
Mon Dec 10 2012 10:58pm |
