Home > General > Xenon bulb failing |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
If the bulb is lighting it will be the started failing. Bulb will not light if failed. Am sure the unit will be covered, the bulb won't be but is @ £70. The starter unit is nearer £400. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Mon Dec 03 2012 10:37am |
lee551247 Member Since: 23 Aug 2012 Location: Cheltenham Posts: 287 |
Thanks for the reply, It is going in next tuesday to have 'knocking suspension' sorted on it so I'm guessing they will do it with that. I hope they do replace the starter under warranty if its around £400 |
Mon Dec 03 2012 10:41am |
Anti roll bar rubbers or bottom ball joint. Not uncommon. If they don't replace unit under warrentee they need drop kicked. I have a known working second hand unit if your stuck. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Mon Dec 03 2012 11:00am |
Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268 |
mine went pink a few weeks ago.. then came back to normal... and now flicker.. ordering new bulbs today Why?.. Because i can....
Mon Dec 03 2012 11:17am |
Thanks for your help guys |
Tue Dec 04 2012 11:24am |
Mine has done this now! Have you replaced your bulb yet? |
Thu Dec 06 2012 9:57am |
Waiting for the delivery to turn up .. will let you know Why?.. Because i can.... RRS 2006 S/C Rimini Red Weekend toy Subaru impreza 1998 2.0 340hp still here Smart car 0.7 61 hp Carbon offset Sierra cosworth 2.0 350 hp GONE Various RS escorts, Vauxhall sri's Volvo T5's, BMW 3 series, fiestas (?) fiat's.... Mr Mischief - www.mischief-inc.co.uk |
Thu Dec 06 2012 10:48am |
Its here and 2 new bulbs fitted.. So far so good ... Will report back if any further issues Why?.. Because i can....
Sat Dec 08 2012 6:49pm |
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 401 |
I just mounted some LED side lamps
Sat Jan 26 2013 11:25am |
Im sure xenon bulbs are covered by the original 3yr warranty, but not extended warranty Mike
Sat Jan 26 2013 12:53pm |
Sag Member Since: 07 Jul 2009 Location: Leicester Posts: 564 |
I got these last month to match my LED sidelights, been great so far with a nice OEM Blue tint http://www.hids4u.co.uk/philips-d2s-bulb-x...85122.html LCFC. Receiver of threatening letters from Overfinch. |
Sat Jan 26 2013 4:10pm |
