![]() | Home > General > Xenon bulb failing |
If the bulb is lighting it will be the started failing. Bulb will not light if failed. Am sure the unit will be covered, the bulb won't be but is @ �70. The starter unit is nearer �400. |
lee551247 Member Since: 23 Aug 2012 Location: Cheltenham Posts: 287 ![]() ![]() |
Thanks for the reply, It is going in next tuesday to have 'knocking suspension' sorted on it so I'm guessing they will do it with that. I hope they do replace the starter under warranty if its around �400 ![]() |
Anti roll bar rubbers or bottom ball joint. Not uncommon. If they don't replace unit under warrentee they need drop kicked. I have a known working second hand unit if your stuck. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268 ![]() ![]() ![]() |
mine went pink a few weeks ago.. then came back to normal... and now flicker.. ordering new bulbs today |
Thanks for your help guys |
Mine has done this now! Have you replaced your bulb yet? |
Waiting for the delivery to turn up .. will let you know ![]() RRS 2006 S/C Rimini Red Weekend toy Subaru impreza 1998 2.0 340hp still here Smart car 0.7 61 hp Carbon offset Sierra cosworth 2.0 350 hp GONE Various RS escorts, Vauxhall sri's Volvo T5's, BMW 3 series, fiestas (?) fiat's.... Mr Mischief - www.mischief-inc.co.uk ![]() |
Its here and 2 new bulbs fitted.. So far so good ... Will report back if any further issues Why?.. Because i can....
Fatandre Member Since: 05 Oct 2009 Location: Reykjav�k Posts: 402 ![]() ![]() ![]() |
I just mounted some LED side lamps
Im sure xenon bulbs are covered by the original 3yr warranty, but not extended warranty Mike
Sag Member Since: 08 Jul 2009 Location: Leicester Posts: 564 ![]() ![]() ![]() |
I got these last month to match my LED sidelights, been great so far with a nice OEM Blue tint http://www.hids4u.co.uk/philips-d2s-bulb-x...85122.html LCFC. Receiver of threatening letters from Overfinch. |
