Home > General > Xenon bulb failing
lee551247
Xenon bulb failing
I have a xenon bulb which has dimmed and gone a red ish colour, I presume this is the bulb starting to fail. Are these covered by Land Rover warranty?
Post #365224 Mon Dec 03 2012 8:41am
simple1
If the bulb is lighting it will be the started failing. Bulb will not light if failed. Am sure the unit will be covered, the bulb won't be but is @ £70. The starter unit is nearer £400. Censored 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #365232 Mon Dec 03 2012 10:37am
lee551247
Thanks for the reply, It is going in next tuesday to have 'knocking suspension' sorted on it so I'm guessing they will do it with that. I hope they do replace the starter under warranty if its around £400 Shocked
Post #365233 Mon Dec 03 2012 10:41am
simple1
Anti roll bar rubbers or bottom ball joint. Not uncommon. If they don't replace unit under warrentee they need drop kicked. I have a known working second hand unit if your stuck. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #365234 Mon Dec 03 2012 11:00am
Montythegod
United Kingdom 2006 Range Rover Sport Supercharged Rimini Red
mine went pink a few weeks ago.. then came back to normal... and now flicker.. ordering new bulbs today Smile Big Cry Why?.. Because i can....
RRS 2006 S/C Rimini Red Weekend toy
Subaru impreza 1998 2.0 340hp still here
Smart car 0.7 61 hp Carbon offset
Sierra cosworth 2.0 350 hp GONE
Various RS escorts, Vauxhall sri's Volvo T5's, BMW 3 series, fiestas (?) fiat's....
Mr Mischief - www.mischief-inc.co.uk Wink
Post #365237 Mon Dec 03 2012 11:17am
lee551247
Thanks for your help guys Smile
Post #365397 Tue Dec 04 2012 11:24am
lee551247
Mine has done this now! Have you replaced your bulb yet?
Post #365598 Thu Dec 06 2012 9:57am
Montythegod
Waiting for the delivery to turn up .. will let you know Thumbs Up Why?.. Because i can....
Post #365600 Thu Dec 06 2012 10:48am
Montythegod
Its here and 2 new bulbs fitted.. So far so good ... Will report back if any further issues Why?.. Because i can....
Post #365901 Sat Dec 08 2012 6:49pm
Fatandre
Iceland 2006 Range Rover Sport Supercharged Santorini Black
I just mounted some LED side lamps
My headlights are red/yellowish and it should mean it is failing , right?
What xenonbulbs to go with to mach the Leds. Maybe something a little bit blueish?
What do you think? 91 BMW 850CSI
Post #371031 Sat Jan 26 2013 11:25am
mse
Im sure xenon bulbs are covered by the original 3yr warranty, but not extended warranty Mike
2014 Facelift Discovery
Post #371035 Sat Jan 26 2013 12:53pm
Sag
What do you think?
I got these last month to match my LED sidelights, been great so far with a nice OEM Blue tint
http://www.hids4u.co.uk/philips-d2s-bulb-x...85122.html LCFC. Receiver of threatening letters from Overfinch.
Post #371044 Sat Jan 26 2013 4:10pm
