![]() | Home > Technical > Electronic Park Brake (EPB) problem. |
V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145 ![]() ![]() |
" I have now "disabled the brake" by when ignition off, pressed the releaseswitch, and holding it down
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
The most likely things are,either the handbrake shoes require adjustment, so that the actuator doesn't try to overtravel (causing the screeching noise), or (as in my case) the shoe linings on one side had disbonded and disintegrated to a pile of dust causing the same screeching and overtravelling. Continuing to apply the park brake in this condition will eventually damage the actuator. I recommend perusing 'Bodsy's Brake Bible' on here, an excellent guide on how to strip down /clean / replace / the park brake shoes (and main brakes), and then adjust them correctly so as not to screech on application. Or if you don't feel confident, take it to a dealer, but be warned, even they do not always get this right (my problem was caused by dealer not adjusting p/b shoes correctly) |
IMO the drive-away capability on the EPB should only be used when going forward. You need to release the brake before reversing; it spund as if you've damaged the auto-release mechanism. |
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 ![]() ![]() |
I've had the 'squeeling cat' problem. As texstar said above it was the actuator that had failed due to incorrect adjustment of park brake. Land rover wanted £1100 to sort out, Land Rover specialist £800. Apparently caused by the parking brake not being adjusted correctly during service. |
I had a problem recently when parking brake engaged with a horrible noise but won't release making even more noise. Turned out the brake shoes had some mud left in them after offroading and were overheating on every park brake application. One of the shoes had eventually disintegrated but had damaged the disc too. Rear discs and shoes needed to be replaced. |
