Home > General > non start
brettb
United Kingdom 2006 Range Rover Sport TDV6 HSE Rimini Red
non start
Hi all
I have a 2006 2.7 TDV6, I have had the car since jan this year. sometimes when the weather is cold and damp the car will
run for a second or so when I start it. Then it cuts out and will not start it turns but will not fire up. If I leave it for an hour or so when I try again it runs fine. It has been into the Land Rover garage a couple of times and I have had the AA out to it no joy there.
There are no stored faults in the memory either. It only happens when I have to be somewhere. I would say it has done it half a dozen times now and it is starting to get on my wick and I want to sort it. The car has fuel in it I use the pre heat twice. It will be fine for a few weeks then it will do it again, and as it is getting colder it will do it more often. Any one got any ideas.
Thanks
Brett
Post #359813 Mon Oct 15 2012 10:05pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
I'm new to diesels myself but my guess would be glow plugs. Is it taking longer than usual to pre heat? It maybe that it's not getting hot enough and the cold diesel cools it down before it can light it.
Is the battery losing charge over night?
I'm just guessing - I'm sure someone with more diesel experience will come along soon.
Post #359819 Tue Oct 16 2012 12:25am
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Re: non start
brettb wrote:
Hi all
Thanks
Brett
Had the same prob with my 2006 HSE. Lucky for me the prob was solved after a new battery. To many short trips with a diesel and the battery are empty in seconds.... Thumbs Up RRS 2006 2.7 HSE
Post #359832 Tue Oct 16 2012 8:25am
simple1
Modern diesels will start without heating due to direct injection and higher compression unless its minus stupid degrees. If it fires its not glow plugs, sounds more like damp in a plug or sensor. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #360095 Thu Oct 18 2012 9:31pm
