Home > Tips & Tricks > EPB Service Mode
bootz
EPB Service Mode
Procedure to clean out the EPB mechanism;
maybe best to consult your local dealer on this one to avoid any confusion.
Post #359433 Thu Oct 11 2012 10:39pm
Bodsy
Site Sponsor
Whoah!
That's not a service mode, that's the epb bedding in mode by the sounds of it. Are you sure 'service mode' came up on the display?
Sure fire way to wear your epb shoes out if you use it too much. Especially if your not doing the adjustment of the epb shoes as well. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #359434 Thu Oct 11 2012 11:08pm
bootz
Bodsy,
i have heavily edited the OP as I don't want to put out any info that may be either incorrect or misleading. The procedure originally described was exactly as explained to me by LR service and certainly improved the braking efficiency of the EPB on my vehicle which clearly needed a clean-out.
The procedure was not a normal everyday braking operation, but to be used after off-roading (particularly after wading) and also after winter road use, as debris, grit, rust etc accumulates and reduces brake effectiveness.
bootz
Post #359436 Fri Oct 12 2012 12:06am
Bodsy
Site Sponsor
I personally think its not the best advice from LR and is the first time I've heard the procedure used in that way.
That procedure is listed in my brake bible but only for bedding in. Thumbs Up Bodsys Brake Bible
See it HERE
Post #359438 Fri Oct 12 2012 5:29am
Gerico
Re: EPB Service Mode
......Have I missed something...... Shocked
Post #359489 Fri Oct 12 2012 7:09pm
Bodsy
Site Sponsor
Boots, I've just been speaking to a LR guy and his advice was to only put it into that mode to reset it all, but not to do the actually driving with it. Thumbs Up Bodsys Brake Bible
See it HERE
Post #359524 Sat Oct 13 2012 11:51am
kttlaweb
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Bodsy can i PM you, I really could do with picking your brains regarding my EPB, and you seem like the man to ask around here?
Post #504024 Mon Aug 29 2016 8:30pm
Bodsy
Site Sponsor
Sure, hit the PM button at the bottom of any of my posts. Thumbs Up Bodsys Brake Bible
See it HERE
Post #504061 Tue Aug 30 2016 9:03am
