Home > Technical > issue with intermittent heavy steering
shepp
Hello all.
Just notices the other day, the steering. Kept becoming heavy, but not a complete failure way but like how steering gets heavier with speed.
Also the power on the steering seemed to have a slight delay. so i am thinking an issue with a sensor somewhere. Steering angle etc ???
Any help will be greatly appreciated.
Thanks
Post #358601 Wed Oct 03 2012 10:40am
Personally I'd look for a slipping steering pump belt... but I'm not sure a RRs has one..
Waiting for a techie to pop up Thumbs Up RRS gone
Post #358608 Wed Oct 03 2012 11:22am
Bodsy
Site Sponsor
its probably just the steering column UJ a bit of spray grease should make it better for a while. Replacement is about £50ISTR + fitting of course. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #358625 Wed Oct 03 2012 2:34pm
shepp
Hello , its definitely not a slipping belt, it feels more electrical as though there is a faulty sensor, and it has not sensed the movement of the steering wheel. And it also does not really feel to be a uj as other can be perfectly ok at times then suddenly play up. I think the sc has speed dependant steering. So could be a sensor?
Post #358627 Wed Oct 03 2012 3:45pm
shepp
Post #358628 Wed Oct 03 2012 3:45pm
shepp
Post #358629 Wed Oct 03 2012 3:45pm
Could you repeat that just one more time please Shepp Laughing Wink
Post #358647 Wed Oct 03 2012 9:34pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
same problem i have
Post #364242 Fri Nov 23 2012 8:22pm
drdelrrs
I assume you've checked the power steering fluid level?
If you open the hood and, with the engine running, turn the steering wheel from loct to lock quickly does it turn smoothly and quietly?
If the belts squeal that's the issue/
If you smell rubber after a few attempts you have a sticking pump
If neither of above you may have a steering rack which is faulty or even slightly bent!
Post #364302 Sat Nov 24 2012 12:12pm
ShooterNeil
Looked at the fluid today and in was on minim topped up to max now so will see if it drops in the week think its 50% better but only drove 2 miles home after the top up
Post #364389 Sun Nov 25 2012 5:18pm
