![]() | Home > Technical > issue with intermittent heavy steering |
Personally I'd look for a slipping steering pump belt... but I'm not sure a RRs has one..
its probably just the steering column UJ a bit of spray grease should make it better for a while. Replacement is about £50ISTR + fitting of course. Bodsys Brake Bible
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Hello , its definitely not a slipping belt, it feels more electrical as though there is a faulty sensor, and it has not sensed the movement of the steering wheel. And it also does not really feel to be a uj as other can be perfectly ok at times then suddenly play up. I think the sc has speed dependant steering. So could be a sensor? |
Could you repeat that just one more time please Shepp |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
same problem i have |
I assume you've checked the power steering fluid level?
Looked at the fluid today and in was on minim topped up to max now so will see if it drops in the week think its 50% better but only drove 2 miles home after the top up |
