Home > Maintenance & Modifications > gearbox oil change
GIXER JOHN
2006 Range Rover Sport TDV6 HSE Santorini Black
gearbox oil change
Hi all
Going to change gearbox oil on my 2006 2.7 sport @ the weekend.
need to know if Dexron 3 (auto 15 ) or fully synthetic 75/90 GL5 WOULD BE OK
I am a plant mechanic so have oil in stock .
have been advised by oil supplier that dexron 3 is ok but not sure.
any help would be welcome.
thanks Question
Post #358072 Thu Sep 27 2012 11:42am
I was warnewd not to use anything other than LR approved ZF Lifeguard
The gearbox specialist near me also said the same. RRS gone
Post #358076 Thu Sep 27 2012 12:41pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Are nt these gear boxes sealed for life?
Post #358078 Thu Sep 27 2012 12:57pm
100k service I think. RRS gone
Post #358085 Thu Sep 27 2012 2:13pm
Mike767
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
There is a load of information on this subject over on the D3 site. Supposedly sealed for life, but lots of reports of gearbox shudder under load. I assume the same box is fitted to the RRS 2.7, but I'm a new RRS owner.
The Shell spec oil is seriously expensive and only available in 1 litre bottles. I went with Millermatic ATF DM for my D3 and it cured the shudder after a double flush. Plenty of people have used alternative oils with no problems.
Post #358086 Thu Sep 27 2012 2:13pm
airwolf222helicopters
gearbox oil change
hi I changed mine myself
you must use the specifide oil otherwise you can get a oil curdle and thats bad news
not the easiest of jobs 7 ltres LR say but when I done mine only got 4.5 back in which I was told from LR was good as alot of oil stays in transfer box
shudder cured on mine
Post #358121 Thu Sep 27 2012 8:02pm
Disco_Mikey
Gearbox oil is recommended at 150k/10 years, but well worthwhile replacing at 75k. Also consider erplacing the sump/filter assy at the same time.
Your local Britpart dealer can supply you with a gearbox service kit, which includes the sump/filter and ZF Lifegaurd 6 oil
Alternatively, the only oil we have found which appears to meet LR's own spec is made by Ravenol, and is slightly cheaper: http://ravenol-shop.co.uk/shop/category_72...=cid%3D%26
We have never used it ourselves in the workshop though, so cannot comment on how well it works Thumbs Up
Post #358138 Fri Sep 28 2012 4:51am
Paddi
LR are always a good source of duff information " .....I was told from LR was good as a lot of oil stays in transfer box ". Rolling with laughter Rolling with laughter Well it would wouldn't it since the transfer box is a separate unit with its own oil of a different specification?
I think LR will find it is the torque converter that retains half the oil.
Great advice from Disco Mikey Bow down Bow down - thanks I'm planning to do exactly what you suggest. As I understand it the old plastic sump with integral filter has to be pulled off which involves breaking a plastic pipe and then replaced with the new after market sump which is metal and has a replaceable filter? Any tips on exactly how to go about this job would be much appreciated. I'm hoping changing the oil might fix the odd problem my car has with the very occasional (once on a 50 mile trip) hard shift. 2008 MY Java Black TDV8 HSE
Post #358164 Fri Sep 28 2012 11:40am
Disco_Mikey
The old sump does not need to be broken to be removed. The transfer box needs raised, and the O/S engine mount needs unbolted and the engine raised up, but it does come out
The aftermarket steel sump does come with a seperate filter, and is much easier to fit. No idea on price though
Post #358165 Fri Sep 28 2012 11:50am
mse
Thud Mike
2014 Facelift Discovery
Post #358172 Fri Sep 28 2012 3:39pm
Disco_Mikey
The Britpart kit uses a Genuine LR sump pan, and ZF Lifeguard 6 fluid.
The 1 and only time I would recommend Britpart Laughing
Post #358183 Fri Sep 28 2012 5:17pm
Paddi
Pearls of wisdom Disco Mikey; much appreciated - is it the same for my TDV8?
and wow a positive comment for sCensoredt part; the first ever. 2008 MY Java Black TDV8 HSE
Post #358185 Fri Sep 28 2012 5:28pm
Disco_Mikey
Never done a TDV8 yet.
Have done a few TDV6, and petrol V8's. Can only imagine the TDV8 would be the same as the petrol V8, as the downpipes take a pretty similar route Thumbs Up
Post #358186 Fri Sep 28 2012 6:07pm
mse
If thats the case, then Thumbs Up - never been a britpart part that i would trust in a sensitive area Mike
Post #358190 Fri Sep 28 2012 6:45pm
Tim Hoang
Can someone recommend a garage to do the gearbox oil change in SE London/Dartford area ? My RRS is up to the mileages. Thanks in advance. 2005 RRS TDV6 HSE Java Black
2005 997 C2
Post #358721 Thu Oct 04 2012 12:08pm
