![]() | Home > Technical > Air Conditioning troubleshooting - Main Dealer/Specialist ? |
Gibbsy1966 Member Since: 25 Apr 2012 Location: Derbyshire Posts: 73 ![]() ![]() ![]() |
I've got the same issue with my wife's 2005 S/C ...was about to get it re-gassed but would appreciate any thoughts on whether this will resolve the issue...ta BMW 530D 2011 still here
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 ![]() ![]() ![]() |
From my experience, the person I bought it from allegedly had it regassed between us seeing it first and purchasing it. We took his word for it and didn't test the AC until a few days later, only to find it warm.
Thanks....luckily my daughter-in-law's father owns a garage and specialises in A/C so let's see what he can do. if it resolves it I'll let you know BMW 530D 2011 still here
He's not close to Berkshire by any chance ? |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Mr Frog don't mess about with amateurs go to a professional http://www.vanchilla.co.uk/ Speak to John, he does all our fridge vans and has done an excellent job for 20 years. If the franchise dealers get stuck with a problem car they give it to him to sort out. Good luck. |
Thanks will give them a call ![]() ![]() "Roads ? Where we're going there are no roads." Back to the future. |
Let me know how you get on? |
Dave Gilbert Member Since: 14 Aug 2009 Location: Banyoles Posts: 3 ![]() ![]() ![]() |
When was the pollen filter last changed? Makes a massive difference to the functioning of the aircon. Mine was getting worse and worse until they changed the filter at a service and then it was like new again. Might not be your problem of course but worth checking. |
Pollen filter was changed at last service two weeks ago.
Sorted, drove there this afternoon after a short phone call ! Took a little while to figure it out, but John's a true professional and even when I was happy all was in order, he was still looking and scratching his head to make sure we hadn't run to early conclusions. Seems there may have been a mix of gases in the air-con and the various people who looked at it weren't professional enough to admit to their mistakes or know what could be wrong. The air-con wasn't cold when we first looked at the car, asked for it to be regassed which we were told was done, but didn't check before driving off. Following day, before heading up north on a long trip, I popped into Kwik Fit for a recharge but that made no difference, and John reckons this may be where they mixed gasses and brushed the no-better air-con performance as an expensive problem with the compressor. Can't recommend John enough, many many thanks for the pointer. Didn't cost all that much in the end either. I'll definitely go back to him if I ever need anything air-con related. ![]() "Roads ? Where we're going there are no roads." Back to the future. |
So pleased you got it sorted out, we would be stuck without John he is one of a kind and old school! |
Great result Mr Frog... Still haven't got around to sorting mine out and off to Norgolk this weekend..26 degrees forecast !! BMW 530D 2011 still here
He is indeed and that's a good thing ![]() ![]() "Roads ? Where we're going there are no roads." Back to the future. |
