Home > General > Advice On TDV8 Problems - Dealer Can't/Won't Help
Page 3 of 5 <12345>
Gary
Have you considered new TPMS valves for your 22" and having it recalerbrated?
Post #355799 Thu Sep 06 2012 8:03pm
whatpothole
I'm not sure it would work, as the 22" tyres seem to need around 40psi, otherwise they virtually run on the shoulders.
This seems a common situation with this wheel/tyre size, as most owners seem to run their tyres around that pressure.
I don't know if this would cause TPMS to report that the pressures are too high, or if this is something else that could be recalibrated by someone in the know?
Post #355800 Thu Sep 06 2012 8:10pm
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
Might be worth asking BBS Solutions if it's something that can be done with their Faultmate MSV unit, then find someone who has one and is prepared to help.
It seems to be able to do most things dealers can do and more, maybe even calibrate tpms pressures to suit your wheels, don't know for sure.
"Roads ? Where we're going there are no roads." Back to the future.
Post #355806 Thu Sep 06 2012 8:18pm
whatpothole
Thanks - I've just sent a message to BBS asking whether this is possible, or whether the Faulktmate MSV can deactivate the system, or tell the car that it's not present.
Post #355858 Fri Sep 07 2012 8:21am
whatpothole
I think a solution to the TPMS problem may be getting closer - reply from BBS is below:
The option to set this as 'not fitted' is available in the CCF and can be set using our Faultmate systems.
Can anyone recommend an independent in the South East, (near Staines/Heathrow ideally), who has a Faultmate?
I'm prepared to travel further afield if necessary.
Thanks,
Rob
Post #355879 Fri Sep 07 2012 1:24pm
mrfrog
Getting closer indeed.
Bodsy on here might be able to help, isn't not darn sarf though (shropshire). There may be others here who can provide a similar service and I don't know of any independents who have one.
See here: http://www.rrsport.co.uk/forum/topic26690....=faultmate
Post #355880 Fri Sep 07 2012 1:31pm
whatpothole
Thanks, I'll give him a try.
It would be worth a 300 mile round trip, just to stop the Censored TPMS messages from flashing up every 5 miles!
Post #355882 Fri Sep 07 2012 1:40pm
mrfrog
The first 150miles will be a pain, the next 150 a pleasure then Laughing
Post #355883 Fri Sep 07 2012 1:44pm
whatpothole
My thoughts exactly! Rolling with laughter
Post #355884 Fri Sep 07 2012 1:54pm
pjb
Possibly James French in Oxfordshire ? Paul
L405 Loire Blue
Swift Conqueror 645
Abarth 500c
Post #355888 Fri Sep 07 2012 3:10pm
mse
Faultmate or Autologic there will be one - ask autologic they will tell you their dealer - if not Warwickshire is close ish! Mike
2014 Facelift Discovery
Post #355892 Fri Sep 07 2012 3:35pm
whatpothole
I've just sent a message to James French, to see if they can help.
If you have a contact in Warwick, I'll give them a try as well?
Thanks.
Post #355893 Fri Sep 07 2012 3:39pm
whatpothole
Unfortunately, no reply from James French, but all set for a trip to see Bodsey on Thursday morning, so hopefully an end to the Censored continual TPMS warnings is in site.
I'm also going to ask him to have a look at the steering position sensor, to see if recalibration is required, so fingers crossed this may sort out the unnecessary traction/skid control intervention.
That just leaves the noisey EGR valves, which I'll possibly take up with LR customer service and see what they say.
I may try and post a link to a recording of the noise, to see if you guys think it's excessive enough to require attention, even though they appear to be still working.
Thanks for all the help and advice so far.
Rob
Post #356218 Tue Sep 11 2012 10:45am
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
oh no, the big wheels invalidate the EGR valves too! Whistle Rolling with laughter ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #356224 Tue Sep 11 2012 12:05pm
mrfrog
Isn't anything an excuse ? Owners' manual states only Land Rover approved accessories should be plugged into cigarette lighters. I guess a phone charger or Sat Nav power lead would invalidate your warranty unless approved by LR ?
Post #356225 Tue Sep 11 2012 12:18pm
Page 3 of 5 <12345>
