![]() | Home > General > Advice On TDV8 Problems - Dealer Can't/Won't Help |
Gary Member Since: 22 Jun 2006 Location: Essex Posts: 268 ![]() ![]() ![]() |
Have you considered new TPMS valves for your 22" and having it recalerbrated? |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 ![]() ![]() ![]() |
Might be worth asking BBS Solutions if it's something that can be done with their Faultmate MSV unit, then find someone who has one and is prepared to help.
whatpothole Member Since: 05 Jun 2012 Location: Middx Posts: 25 ![]() |
Thanks - I've just sent a message to BBS asking whether this is possible, or whether the Faulktmate MSV can deactivate the system, or tell the car that it's not present. |
I think a solution to the TPMS problem may be getting closer - reply from BBS is below:
Getting closer indeed.
Thanks, I'll give him a try. It would be worth a 300 mile round trip, just to stop the ![]() |
The first 150miles will be a pain, the next 150 a pleasure then |
My thoughts exactly! ![]() |
pjb Member Since: 04 Mar 2008 Location: Sunny Oxon Posts: 213 ![]() |
Possibly James French in Oxfordshire ? Paul
Faultmate or Autologic there will be one - ask autologic they will tell you their dealer - if not Warwickshire is close ish! Mike
I've just sent a message to James French, to see if they can help. If you have a contact in Warwick, I'll give them a try as well? Thanks. |
Unfortunately, no reply from James French, but all set for a trip to see Bodsey on Thursday morning, so hopefully an end to the ![]() I'm also going to ask him to have a look at the steering position sensor, to see if recalibration is required, so fingers crossed this may sort out the unnecessary traction/skid control intervention. That just leaves the noisey EGR valves, which I'll possibly take up with LR customer service and see what they say. I may try and post a link to a recording of the noise, to see if you guys think it's excessive enough to require attention, even though they appear to be still working. Thanks for all the help and advice so far. Rob |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
oh no, the big wheels invalidate the EGR valves too! |
Isn't anything an excuse ? Owners' manual states only Land Rover approved accessories should be plugged into cigarette lighters. I guess a phone charger or Sat Nav power lead would invalidate your warranty unless approved by LR ? ![]() "Roads ? Where we're going there are no roads." Back to the future. |
