Home > Maintenance & Modifications > Number Plate Replacement |
Sag Member Since: 07 Jul 2009 Location: Leicester Posts: 564 |
Boiling water usually helps! Should soften up the sticky pads behind them. LCFC. Receiver of threatening letters from Overfinch. |
Fri Jul 20 2012 3:56pm |
Black36 Member Since: 16 Apr 2012 Location: Exeter Posts: 58 |
First of all mark out the outline of the old plate if it’s nice and straight with masking tape, you’ll need this for when you put your new plate on for a guide line.
Fri Jul 20 2012 4:40pm |
sjuggins Member Since: 18 Jun 2012 Location: Bedfordshire Posts: 25 |
Thanks guys for the tips |
Fri Jul 20 2012 5:08pm |
I found it easier to use a heat gun or the wifes hair dryer and heat the plate up starting at one corner, then prise the plate away from the body whilst keep heating the plate, If using a heat gun DO NOT burn the paintwork or melt the plate then clean off any sticky pads as instructions above |
Fri Jul 20 2012 8:23pm |
All done and dusted, took about 10 mins to do front and back |
Fri Jul 20 2012 9:28pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Too late I know, but I'd always recommend some heat and some fishing line/dental floss.
Sat Jul 21 2012 12:36pm |
