![]() | Home > Maintenance & Modifications > Number Plate Replacement |
Sag Member Since: 07 Jul 2009 Location: Leicester Posts: 564 ![]() ![]() ![]() |
Boiling water usually helps! Should soften up the sticky pads behind them. LCFC. Receiver of threatening letters from Overfinch. |
Black36 Member Since: 16 Apr 2012 Location: Exeter Posts: 58 ![]() ![]() ![]() |
First of all mark out the outline of the old plate if it’s nice and straight with masking tape, you’ll need this for when you put your new plate on for a guide line.
sjuggins Member Since: 18 Jun 2012 Location: Bedfordshire Posts: 25 ![]() ![]() ![]() |
Thanks guys for the tips |
I found it easier to use a heat gun or the wifes hair dryer and heat the plate up starting at one corner, then prise the plate away from the body whilst keep heating the plate, If using a heat gun DO NOT burn the paintwork or melt the plate |
All done and dusted, took about 10 mins to do front and back |
Too late I know, but I'd always recommend some heat and some fishing line/dental floss.
