![]() | Home > Maintenance & Modifications > 2010 LED rear Light conversion |
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 ![]() ![]() ![]() |
do it! |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 ![]() ![]() |
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 ![]() ![]() |
okey dokes.... How do i upload pics to this site? Ill do it tomoz night.. Hopefully will help some peeps put |
moparmuff Member Since: 25 May 2012 Location: S. Bucks Posts: 96 ![]() ![]() ![]() |
Yes great idea, I preume the resistors are soldered in the light units ? |
not had a min tonight. Had fambo round for tea. I have soldered my resistors into the car harness, but basically the same to mount them to the lights... Only prob soldering them to the lights is mounting the Resistor as it get HOT |
no pain.....no gain |
ha ha ha im on it right now!! |
HOW TO... 1st of all disconnect the negative battery lead to be on the safe side......!!!!!!
Well done looneyfitter |
Wow fantastic write up and lights look fab
Cheers pal, should show people how easy this mod is. I know some start |
What sort of high temp. glue did you use and where from thanks |
From b & q mate it's call duel temp |
Thanks Bud ![]() |
