Home > Maintenance & Modifications > 2010 LED rear Light conversion
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Did this conversion tonight on my 55plate hse. Fitted resistors etc from ebay. Ive gotta say it looks the mutts nuts and was suprisingly easy. Took loads of pics too. JUst wondering if it would be worth while me doing a little tutorial with pics as i couldnt really find a link with the HOW TO Thumbs Up What you recon? Very Happy
Post #350233 Mon Jul 09 2012 9:14pm
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
do it! Thumbs Up RRS 2006 2.7 HSE
Post #350235 Mon Jul 09 2012 9:17pm
rigsby
Thumbs Up Thumbs Up MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #350236 Mon Jul 09 2012 9:20pm
looneyfitter
okey dokes.... How do i upload pics to this site? Ill do it tomoz night.. Hopefully will help some peeps put Thumbs Up
Post #350241 Mon Jul 09 2012 9:40pm
moparmuff
England 2008 Range Rover Sport Supercharged HST Java Black
Re: 2010 LED rear Light conversion
Yes great idea, I preume the resistors are soldered in the light units ?
Post #350352 Tue Jul 10 2012 9:26pm
looneyfitter
not had a min tonight. Had fambo round for tea. I have soldered my resistors into the car harness, but basically the same to mount them to the lights... Only prob soldering them to the lights is mounting the Resistor as it get HOT Thumbs Up
Post #350362 Tue Jul 10 2012 9:59pm
rigsby
no pain.....no gain Rolling with laughter Rolling with laughter MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #350363 Tue Jul 10 2012 10:00pm
looneyfitter
ha ha ha im on it right now!! Laughing
Post #350370 Tue Jul 10 2012 10:54pm
looneyfitter
HOW TO... 1st of all disconnect the negative battery lead to be on the safe side......!!!!!!
Right here goes.
Heres how to fit these clusters Very Happy
Goto ebay and buy 2no of this item.. http://www.ebay.co.uk/itm/360449150191?ssP...922wt_1139
1:You need to remove the rear clusters. This is super easy. You need to open your boot and remove the 2 phillips screws holding the cluster in.
2:Then get yourself a flat screw driver and wrap some insulation tape around the tip.
3:Place the screwdriver between the cluster and the body and gently prize the cluster out
4: Gently pull the cluster forward, you will see the grey connector attached to the harness, push the tab and pull the connector apart from each other.
5: Locate PIN 5 (black common Ground) and PIN 3 (green with red trace, indicator wire) of the car loom and use a stanley blade and carefully slice away 10mm of insulation from each of the wires. You could also connect the resistor to the cluster wiring using the same pins but then you have the issue of heat transfer from the resistor. The pin numbers are identified on the back of the plug Thumbs Up
6:Strip back 25mm of the insulation from the resistor wires and twist the ends of each so they dont frey. Then wrap one end of the wire around the BLACK and the other around the GREEN/RED and solder them up. (doesnt matter which way wires of the resistor go)
7: Wait for the joints to cool and wrap them tightly in insulation tape. For those who go wadeing, i would also be tempted to cover the entire joint in either hot glue or silicone Cool
be careful of cragmire's nuts lol Laughing
8: Now to mount the resistor.. This is really personal preferance but please bear in mind, it does get HOT when the indicator or hazards are left on for some time. You dont want it to MELT anything... I personally used high temp glue in my glue gun. You can buy these from any B&Q etc for peanuts....
I located mine on the lower part of the cluster cut out just under bumper level.. Basically just bunged aload on and pressed the resister into it for 5 secs. I left my indicators on for a good 25mins and the resistor was VERY HOT but the glue was fine... It was getting a little soft but cant see it being an issue. (do this at your own risk)
And another with it in situ.
9:Push the new cluster connector into the car loom and test. Should look like this.
And as Mr Haynes would say "re-fit in reverse order".
Same for the other side.. Hope this helps Thumbs Up
Regards
Post #350371 Wed Jul 11 2012 12:02am
rigsby
Well done looneyfitter Thumbs Up good pictures and will definitely be of help to anyone else having a go themselves. Car looking good mate with all the mods. What's next? MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #350376 Wed Jul 11 2012 5:34am
moparmuff
Wow fantastic write up and lights look fab
How does this install differ from the plug and play light conversions available on ebay, I see they fit the resistor to the rear of the light assembly but what do they do with the wiring to make it plug and play.
Post #350377 Wed Jul 11 2012 6:29am
looneyfitter
Cheers pal, should show people how easy this mod is. I know some start Censored there pants at the mention of a RESISTOR.
Next is a full Java White & Santorini Black Re-spray Thumbs Up
Post #350378 Wed Jul 11 2012 6:30am
moparmuff
What sort of high temp. glue did you use and where from thanks
Post #350431 Wed Jul 11 2012 3:47pm
looneyfitter
From b & q mate it's call duel temp Thumbs Up
Post #350440 Wed Jul 11 2012 5:05pm
moparmuff
Thanks Bud Thumbs Up
Post #350454 Wed Jul 11 2012 7:11pm
