Home > General > How the hell do you change the front windscreen wipers?! |
Gibbsy1966 Member Since: 25 Apr 2012 Location: Derbyshire Posts: 73 |
Hi Mike
Sun Jun 03 2012 5:09pm |
Mike_C Member Since: 19 Mar 2012 Location: Bucks Posts: 184 |
Hi Gibbsy - thanks, but it's point 1 that is causing issues! I can only lift the wiper arm about 15-20mm away from the screen, not far enough to flick the wiper upside down! It seems to be prevented from lifting up at the hinge somehow, but both front wipers are the same...? - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
Sun Jun 03 2012 5:36pm |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 |
Mike, my wiper arms can be moved approx 4 or 5" from the screen max,(not sure if LR have altered these on some models to make it awkward for owners to do this job ), but that is not enough to flip the blade over, you won't be able to do that, you'll have to angle the blade away from the arm enough to be able to press the little tab that releases the blade with your finger (or a small flat screwdriver). Best to have the new one to hand to slot in straight after removing the old one too. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
Sun Jun 03 2012 6:34pm |
Hi Texstar, I'm not the only one, then! It says in the handbook to flip the wiper blade over to access the clip though, which confuses me! - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
Sun Jun 03 2012 6:52pm |
uffington15 Member Since: 25 Apr 2012 Location: Alhama de Murcia Posts: 25 |
Done mine by taking it to Halfords and I stayed dry |
Sun Jun 03 2012 7:13pm |
I'm not paying £2.99 for a teenager to snap my wiper arm off trying to do what I'm trying to do!! - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE) - BMW 330Ci M-Sport coupe - Suzuki GSX-R750 K6 'Stealth' - trackdays and high speed tourer |
Sun Jun 03 2012 8:00pm |
You don't need to flick the wiper upside down...
Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Sun Jun 03 2012 9:00pm |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 697 |
The wipers are stupid on our cars I tried doing mine a while back I managed the drivers side but give up with the passenger side it hardly moves without nearly braking sumthing Java black 2006 |
Sun Jun 03 2012 9:02pm |
Sag Member Since: 07 Jul 2009 Location: Leicester Posts: 564 |
Mine only lift a few cm away from the screen too, thought it was a fault to be honest. LCFC. Receiver of threatening letters from Overfinch. |
Sun Jun 03 2012 9:03pm |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
You only need to lift the arm enough to get access to the clip then slide the blade forward and off the arm. Fitting is just a matter of positioning the new balde over the end of the arm and pushing on til it clicks into place. Once youve done it, it all makes sense FF 4.4 V8 Soooo looking forward to this bad boy
Mon Jun 04 2012 7:01am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
I had a fight with the arm when I first changed the blades on the RRS. Once you've done it once, it's ok.
Mon Jun 04 2012 8:16am |
OK, thanks guys! I'll try again today, now it's not bucketing down with rain!! - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
Mon Jun 04 2012 9:20am |
rabbutler Member Since: 11 Dec 2009 Location: Aberdeen Posts: 187 |
As Bobby says, you dont have to flip the blade upside down.
Mon Jun 04 2012 12:39pm |
dirtybarrys Member Since: 23 May 2007 Location: UK Posts: 18 |
I'm trying to replace the wiper blades withe Bosch ones. They are not RR ones but I can't fit the arm through the hole in the wiper blade because the arm doesn't move out more than about 4". Anyone have a solution??? |
Thu Jan 24 2013 9:08pm |
