![]() | Home > My Range Rover Sport > My 2006 TDV6 HSE |
Sounds like you have a EGR valve or valves sticking intermittently |
Sag Member Since: 07 Jul 2009 Location: Leicester Posts: 564 ![]() ![]() ![]() |
You guys all seem very knowledgeable on this issue which is great news for me.
I'd see what they come up with, then if EGR valves isn't one of the things, give them a steer in that direction |
Might be worth checking the intercooler pipe for splits too... |
Sag, the first thing the dealer will do is plug in his magic box to your ecu and that will give him any fault codes that are recorded, by the sounds of it they might be a few, then go from there, as said above give them a nudge towards the egr valves if you have to. |
Cheers guys, all your help has been priceless thus far!
I knew I should have bought another Q7 |
So where have the L/R engineers been hiding for the last few years then |
It's crazy because as a 2006 car you could blank the egr's off and be running fine in no time. RRS gone
Some of this stuff you really couldn't make up |
mark hamster Member Since: 26 Nov 2011 Location: nottingham Posts: 116 ![]() ![]() ![]() |
i have same car and same year.i had mine replaced and all been good since |
Hi guys |
Glad the trip went OK and the RRS didn't leave you stranded anywhere sag.
Car is back in at LR today!
