Home > General > Belt change?
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Belt change?
I have been told today that the rear belt,that is the one everyone is scared of(cost wise,body off job)would do no damage if it snapped.Apparently the car would just stop as it just runs the injectors(I think he said)The front belt is the important one and I can have this done for £350.This is at an approved LR Garage with 70 years experiance.
Both belts they do for £650.
Mine hasn't reached the mileage yet but its worth knowing and I'm thinking of having it done as a piece of mind thing(car has 88k on it)
Also B service £226
A service £266
Transmission fluid change £80
Anyone heard this before?
Steve
Post #341857 Mon Apr 30 2012 2:54pm
Bodsy
Site Sponsor
The rear belt, yes, it only poswers the fuel pump and is not relating to the engine timing.
you can get both belts done for less than that although still cheaper than the best part of £1,000 LR charge....
A & B service prices you have there are not bad at all.
Transmission fluid, if they are using the Shell M1375.4 spec, then that is impossibly cheap.... I suspect thatt hey are using something 'similar' but I can guarantee wont be the longlife fluid, in which case its fine, but change it every year instead.
HTH Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #341864 Mon Apr 30 2012 3:08pm
mrfixit
Cheers nice to hear confirmation.I thought the transmission fluid change sounded cheap due to the actual fluid costs,but he assured me it is rated for another 75k
Post #341868 Mon Apr 30 2012 3:16pm
Bodsy
Site Sponsor
its not the longlife stuff then which is 'rated' to 150k.
If it was me with that cheaper fluid, I would be changing it each year (I drive about 22k miles/year) but that's just me. Thumbs Up Bodsys Brake Bible
See it HERE
Post #341870 Mon Apr 30 2012 3:18pm
Ravenol do a shell equivilent transmission oil with cost at around 50% of the shell
Is this longlife Bodsy? RRS gone
Post #341871 Mon Apr 30 2012 3:21pm
Bodsy
Site Sponsor
I can't tell, the website only states that it is LR TYK500050 equivalent which is as we know Shell M1375.4
So could be same spec, but not super long life, sorry I can't be more helpful. Bodsys Brake Bible
See it HERE
Post #341875 Mon Apr 30 2012 3:33pm
mrfixit
I do about 3k a year in it
Post #341876 Mon Apr 30 2012 3:36pm
Bodsy
Site Sponsor
it'll probably be fine then Laughing Thumbs Up Bodsys Brake Bible
See it HERE
Post #341877 Mon Apr 30 2012 3:42pm
Taken from the PDF tech sheet they sent me...but I cannot understand it TBH..
Description:
RAVENOL ATF 6HP Fluid is an automatic transmission fluid (ATF), produced with a blend of hydrocrack oils and synthetic PAO with special additives and inhibition which guarantees a perfect function of the automatic transmission.
RAVENOL ATF 6HP Fluid is one of the latest family of ATF's and is suitable for the newly developed
generation of all 6-speed ZF automatic transmissions.
RAVENOL ATF 6 HP Fluid has a neutrally brown colour.
Application:
RAVENOL ATF 6 HP Fluid was developed specifically for use in the latest ZF 6HP-series transmissions, 6HP19, 6HP21, 6HP26, 6HP28, 6HP32, 6HP34, also for 5-speed automatic transmission 5HP-series. It is backwardly compatible for all earlier versions of ZF 4 and 5 gear passenger car automatic transmission with the exception of 6 HP26A61 in vehicles with AUDI W12 (only original VW G055162A2 blue) and 6HP19X for AUDI Q7, 6HP19A, 6HP28AF (only original VW G060162A2green).
Specifications:
RAVENOL ATF 6 HP Fluid corresponds to the automatic transmission specifications ;
BMW 83220144137 ATF M1375.4 83220142516
FORD MERCON SP XT-6-QSP (6R60, 6R75, 6R80)
Jaguar C2C 8432
Land Rover TYK50 0050
VW / AUDI G 055005 A1/A2/A6
ZF S671 090 252 /3 /5
Characteristics:
RAVENOL ATF 6 HP Fluid offers:
a very good lubricating ability even at low temperatures
a high, stable viscosity index
a very low pour point
exceptional protection against corrosion and foam formation
good balanced coefficient of friction
neutral behaviour with all types of sealing materials
a high thermal and oxidation stability
excellent cooling abilities
an excellent shear stability
lowest evaporation losses
neutral behaviour with all non ferrous metals
Technical values:
Characteristics Unit Data Test according to
Colour brown
Density at 15 °C g/ml 0,850 DIN 51 7 57
Viscosity at - 40 °C mPa ·s(cP) <17900>135 DIN ISO 2592
Pour point °C - 42 DIN ISO 3016
All indicated data are approximate values and are subject to the usual commercial fluctuations.
All information correct at time of going to press to the best of our knowledge . The information herein may be subject to change without notification due to continual product research and development.
For more information, please go to www.ravenol.co.uk or call Ravenol UK distributors on 01244 940660.
11.11.2008
 RRS gone
Post #341879 Mon Apr 30 2012 3:44pm
Bodsy
Site Sponsor
spec reads right, but I can't vouch for it of course
Jaguar C2C 8432
 Bodsys Brake Bible
See it HERE
Post #341881 Mon Apr 30 2012 3:46pm
hoppy_70
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Rimini Red
I've just had a great quote for the same work for mine. Stratstone at bury have an offer on - 599 for both belts and the full year 7 service. This was 260 cheaper than my local specialist.
It's booked in for Thursday. Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Range Rover sport HSE Dynamic P400e Silver
Range Rover Sport 3.0 SDV6 HSE Dynamic 2016 MY
Range Rover sport 3.6tdv8HSE 2007 Gone
Range Rover sport 2.7tdv6SE 2005 Gone
Range Rover sport 2.7tdv6SE 2007 honey
Range rover Vogue 2005 4.4 - GONE and missed
BMW 535d M sport 2006 - GONE not as missed
BMW X5 4.4 2004 sport - GONE
Post #341940 Mon Apr 30 2012 9:49pm
