![]() | Home > General > Belt change? |
The rear belt, yes, it only poswers the fuel pump and is not relating to the engine timing.
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
Cheers nice to hear confirmation.I thought the transmission fluid change sounded cheap due to the actual fluid costs,but he assured me it is rated for another 75k |
its not the longlife stuff then which is 'rated' to 150k.
Ravenol do a shell equivilent transmission oil with cost at around 50% of the shell
I can't tell, the website only states that it is LR TYK500050 equivalent which is as we know Shell M1375.4
I do about 3k a year in it |
it'll probably be fine then |
Taken from the PDF tech sheet they sent me...but I cannot understand it TBH..
spec reads right, but I can't vouch for it of course
Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 ![]() ![]() ![]() |
I've just had a great quote for the same work for mine. Stratstone at bury have an offer on - 599 for both belts and the full year 7 service. This was 260 cheaper than my local specialist.
