Home > Technical > Newbie with a couple of daft ish questions...
neo1
Q1,,, when i engage reverse the parking sensors activate and the switch on the dash for the front ones illuminates im assuming it should, but when i go forward the switch stays illuminated till i turn it off its flashing on and off is that normal ????
Q2,,, O.s.r rear door opens everytime with cetral locking but wont lock so im havong to do it manual its a balls ache, Big Cry i know ive a fault but whats the likely cause..
thanks in advance for anyone who replys Bow down Live life to the full its the only one your getting.
Post #336577 Wed Mar 14 2012 9:01pm
neo1
NO ONE ??? Live life to the full its the only one your getting.
Post #338553 Mon Apr 02 2012 9:39pm
Q1 - the first part is correct, (although I believe the switch on the dash is for both front and rear).
Im not sur about the flashing part, but it should turn off once you increase you speed going forward, approx 15mph. If it doesn't do this and you are having to do it manually, I'd say you have a fault there. Confused
Sorry, can't help with your second query. ON THE WAY: BMW F21 M140i
Post #338570 Tue Apr 03 2012 7:12am
RRS_PAT
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Try this
Seems a fairly common problem with the door locks. See this post
http://www.rrsport.co.uk/forum/topic23170.html?highlight=
Hope it helps Smile
Pat 2011 Autobiography Santorini Black
Post #338572 Tue Apr 03 2012 7:20am
shakeapaw
if you are having to turn the parking sensors off manually, then the front wireing harness will need to be replaced as it has frayed, and water is ingressing, causeing a malfunction, its about £45 for the harness and around 3 hours labour 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #338723 Wed Apr 04 2012 9:36am
neo1
Bloody hell another bloody job this things getting on my tits this range rover..
owned it 6 weeks
alternator and battery
rear boot release handle
rear pads and discs
handbrake motor and cable today £596 job
needs a wheel on cos its buckled
fitted 2 tyres
door locking latch as well
sill needs a service
jesus christ im going bankrupt slowly here Big Cry Live life to the full its the only one your getting.
Post #338814 Wed Apr 04 2012 10:02pm
mmylonas
2006 Range Rover Sport Supercharged Zambezi Silver
only slowly? if you're driving it at all with fuel at current prices then it's a fast road to poverty. and then add on the repairs due to RR (un)reliability..
good luck
Post #339046 Sat Apr 07 2012 1:41pm
firstinretail
United Kingdom 2005 Range Rover Sport 4.4 V8 Siberian Silver
welcome to range rovers, on par in complexity, reliability, and cost as the nasa appolo program........
but good fun when it all works.
Post #339074 Sat Apr 07 2012 7:22pm
