Home > Maintenance & Modifications > Gearbox oil and filter change
robbie1
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
Hi has anyone had a gearbox oil and filter change if so how much will it cost me to get this job done rob telford
Post #335500 Tue Mar 06 2012 9:06pm
From a dealer about £500 Shocked they drain the old oil out then fill with a oil flush drive it around for about 30 minutes, then drain it again, then fill with new gearbox oil, Thumbs Up
Post #335538 Wed Mar 07 2012 9:12am
There are companies out there who offer a similar service for a heap less than dealer costs.
do a search for "megaflush" on google for a local/national company
Thumbs Up RRS gone
Post #335540 Wed Mar 07 2012 9:21am
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
its about £130 for oil and the new pan for the gearbox which includes the filter, my dealer (Riders, now Carrs of truro) did it as part of the service and only charged for the parts
Post #335544 Wed Mar 07 2012 9:58am
robbie1
thanks for that guys going to have it done soon it"s on my list of things to do this year rob telford
Post #335609 Wed Mar 07 2012 5:02pm
Kensta
Will Durham 4x4 not do it 4u Rurb? Java black 2006
Post #335652 Wed Mar 07 2012 8:16pm
ronniet101
new filter and pan
apparently there is a mod now that means the whole pan doesnt have to be changed(apparently filter was integral with it), mod fits new pan and seperate filter
Post #415917 Fri Feb 28 2014 9:50am
jochem00
well that mod is some 10 years old.
do a search on steel pan conversion!
Post #415936 Fri Feb 28 2014 12:39pm
ronniet101
sport only came out in 2005..and if mod was 10 years old then why wasnt it then fitted to all cars after it was introduced
Post #416234 Mon Mar 03 2014 9:39am
jochem00
because that very same gearbox was already introduced in BMWs Jaguars etc more than 10 years ago
Why did LandRover not fit the Steel pan!
well the original oil will last 10 years at least. and they don't want amatures to easily fuss around with the gearbox most probably.
only BMW is offering the steel pan on certain models
Post #416235 Mon Mar 03 2014 9:42am
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
i ve been quoted £450+ vat and thats not a dealer. Anybody know where to get it cheaper in the south coast area?
Post #416245 Mon Mar 03 2014 10:38am
jochem00
quoted for what?
a steel pan conversion including new oil?
that sounds like a very reasonable price as it is a PITA to get the bolts out and new bolts in.
also to remove and reinstall the heatshield bracket can be very time consuming so count some 3 to 4 hours of labour + parts so your quoted price is not bad.
Have a look at my gallery, I just uploaded some picture so you can see how tight it is.
Post #416248 Mon Mar 03 2014 10:41am
SCdavies
thanks. feel better now Very Happy yes they said its for the whole service,oil,filter etc.
Post #416250 Mon Mar 03 2014 10:57am
cactipus
Australia 2007 Range Rover Sport TDV8 HSE Orkney Grey
I just converted to the steel pan. I did it myself (TDV8 2007). I bought the pan on ebay ( make sure you get one with a sump plug). Removal of the plastic sump was a crap job. You're meant to cut the plastic pipe that goes up into the gearbox so that you don't have to lift the engine/gearbox an inch. But it's almost impossible to get a saw in there and you can't see what you're doing. I finally identified more or less where the pipe was with a ruler, marked it on the bottom of the sump and used a 40mm hole cutter, straight through the bottom of the sump, filter and surrounding plastic of the pipe. The pipe was then disconnected and the sump came out.
Filled it with Redline ATF D6. Great results, the car hasn't felt this crisp in ages. ( I tow a fair bit and the car has 77000 k on it.)
Will do one more oil change now since the torque converter wasn't emptied.
Total cost $440 AUD and 4 hours. TDV8 RRS, NAS D90, D2 TD5.
Post #431732 Sun Jul 27 2014 11:40am
