Home > Maintenance & Modifications > Gearbox oil and filter change |
From a dealer about £500 they drain the old oil out then fill with a oil flush drive it around for about 30 minutes, then drain it again, then fill with new gearbox oil, |
Wed Mar 07 2012 9:12am |
There are companies out there who offer a similar service for a heap less than dealer costs.
Wed Mar 07 2012 9:21am |
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 |
its about £130 for oil and the new pan for the gearbox which includes the filter, my dealer (Riders, now Carrs of truro) did it as part of the service and only charged for the parts |
Wed Mar 07 2012 9:58am |
robbie1 Member Since: 11 Dec 2010 Location: blyth northumberland Posts: 71 |
thanks for that guys going to have it done soon it"s on my list of things to do this year rob telford |
Wed Mar 07 2012 5:02pm |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 700 |
Will Durham 4x4 not do it 4u Rurb? Java black 2006 |
Wed Mar 07 2012 8:16pm |
apparently there is a mod now that means the whole pan doesnt have to be changed(apparently filter was integral with it), mod fits new pan and seperate filter |
Fri Feb 28 2014 9:50am |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 |
well that mod is some 10 years old.
Fri Feb 28 2014 12:39pm |
sport only came out in 2005..and if mod was 10 years old then why wasnt it then fitted to all cars after it was introduced |
Mon Mar 03 2014 9:39am |
because that very same gearbox was already introduced in BMWs Jaguars etc more than 10 years ago
Mon Mar 03 2014 9:42am |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
i ve been quoted £450+ vat and thats not a dealer. Anybody know where to get it cheaper in the south coast area? |
Mon Mar 03 2014 10:38am |
quoted for what?
Mon Mar 03 2014 10:41am |
thanks. feel better now yes they said its for the whole service,oil,filter etc. |
Mon Mar 03 2014 10:57am |
cactipus Member Since: 27 Jul 2012 Location: melbourne Posts: 3 |
I just converted to the steel pan. I did it myself (TDV8 2007). I bought the pan on ebay ( make sure you get one with a sump plug). Removal of the plastic sump was a crap job. You're meant to cut the plastic pipe that goes up into the gearbox so that you don't have to lift the engine/gearbox an inch. But it's almost impossible to get a saw in there and you can't see what you're doing. I finally identified more or less where the pipe was with a ruler, marked it on the bottom of the sump and used a 40mm hole cutter, straight through the bottom of the sump, filter and surrounding plastic of the pipe. The pipe was then disconnected and the sump came out.
Sun Jul 27 2014 11:40am |
