![]() | Home > General > Tow bar what the f--- |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
2088??? Does it hover, or go into warpspeed |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
.... ? another £80 bar |
always assume there are no electrics fitted... then you'll never be dissapointed. |
If the previous owner only had a small Erde type trailer from Halfrauds then they may not have needed trailer electrics - I was advised when I damaged the lighting wiring on my Ivor Williams trailer that as, when it is loaded, it didn't obstruct the car's brake and indicator lights then I didn't have to worry about the inoperative trailer lights. This was a police officer who advised me after I had been using my trailer off road................. and he had been following behind me for most of the day in his "works" Defender! His comments didn't stop me from going to the local Ivor Williams centre and getting the wiring and one light unit replaced the day after I got home. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
neo1 Member Since: 21 Oct 2010 Location: Durham Posts: 72 ![]() ![]() |
Local tow bar place is doing me a good deal on a gunuine land rover electrics kit he has in stock that has been orded for someone else that aint been babck all in £90 happy with that fitted..getting done tomorrow.... Live life to the full its the only one your getting. |
Neo, just a point to remember - I'm sure many members here have found out the hard way (a QR Tow hook that won't come out of the socket) never leave the QR hook in the socket for too long, they seem to corrode into place quite quickly and require extreme measures and often a lot of heat to extract when you do need to take them out. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
good point will remove after use for sure... Live life to the full its the only one your getting. |
Good advice.
dynoick Member Since: 14 Feb 2012 Location: uk Posts: 8 ![]() ![]() |
just thought id move the car trailer out and guess what no hook or electrics.why buy a range rover without towing ......go figure |
