Home > Technical > Sat Nav goes off on Engine Start
RRS_PAT
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
I would like some help please - Had a search and couldn't find quite the same thing Sad
When I put the key in my '06 TDV6 HSE and turn to let the system checks run the sat nav comes on. Then when I actually start the engine the screen goes black and the Nav restarts?? I'm pretty sure it didnt use to do this - is this normal??
I checked the battery and alternator with a multimeter and they both seem fine Question
Anyone have any ideas, or do they all do this and I've just forgotten Whistle
Thanks in Advance,
Pat 2011 Autobiography Santorini Black
Post #332552 Wed Feb 15 2012 11:16am
Mine's always done this... more so in the winter which suggests tired battery
Do you get any suspension errors on start up ever? RRS gone
Post #332577 Wed Feb 15 2012 1:37pm
barry15555
England 2006 Range Rover Sport Supercharged Bonatti Grey
+1 Thumbs Up 2006 S/C Bonatti Grey, OEM Steps, LAND ROVFR Mud Flaps, Soft/Smooth steering wheel, 2010/11 HST Wheels.
Post #332592 Wed Feb 15 2012 3:37pm
RRS_PAT
Thanks for the responses guys Thumbs Up
So from an ignorant point of view how do I test if my battery is on the way out as with a multimeter it gave consistently over 12V and with the engine running and full load (CD/heated seats/Air Con) it was still giving around 14??
Thanks,
Post #332622 Wed Feb 15 2012 6:32pm
MAW
You'd be measuring alternator output voltage in that scenario - IIRC you need a discharge test which is semi destructive AIR. This tests the abilty of the battery to hold / maintain charge - not what it is being charged at.
Post #332623 Wed Feb 15 2012 6:48pm
