Home > Technical > WATER IN FOOTWELL
grumans
United Kingdom 2005 Range Rover Sport Supercharged Zambezi Silver
WATER IN FOOTWELL
Hi folks, both my drivers side front and rear footwells are sodden with water. I have cleared all 4 sunroof drains which were blocked and with the carpets pulled back in the front I can't see any visible leaks now. Does anyone know if there are any other common sources for water to get into the drivers side footwells?.
Post #329386 Tue Jan 24 2012 10:12pm
If you put the following in the search box it will bring up a few threads
+water +footwell
Using the + sign in front will only bring threads up with both words,
Post #329390 Tue Jan 24 2012 10:25pm
grumans
thanks for that, it's pointing to the sunroof
Post #329397 Tue Jan 24 2012 10:44pm
Buster007
I had this same problem!!
It turned out to be a sunroof issue I had blocked pipes water was building up around the sunroof outlets and spilling over in to the roof lining, dripping throw the light fitting when I hit the breaks! I used a thin metal flexible sink unblocking rod with tape on the end so not to split the rubber hoses and pushed it down the outlets to unblock the pipes. This worked a treat except next time it rained both my foot wells got wet!! Behind the foot well covers there is a join in the drain pips and I had pushed them apart with the rod!! Just need to remove the foot well covers and rejoin the pipes together - simple!
The drain outlet pipes run from the drain holes around the sunroof down the A pillar behind the foot well covers to an outlet just behind the front wheels.
Hope this helps Thumbs Up Cheers Laurence.
Post #329402 Tue Jan 24 2012 11:02pm
If the RRS has had a windscreen replaced it can cause a leak. 2005 Zambezi TDV6 - Gone but not forgotten
Post #329468 Wed Jan 25 2012 1:01pm
Stuart's the man
had the same problem, sunroof drain tubes, or pollen filter
Post #329888 Sat Jan 28 2012 1:03pm
Buster007
Not heard of the pollen filter causing same problem? Can you tell me more please? Cheers Laurence.
Post #329915 Sat Jan 28 2012 2:22pm
When the screen is replaced the fitter damages the pollen filter box. 2005 Zambezi TDV6 - Gone but not forgotten
Post #329992 Sun Jan 29 2012 12:08pm
leedrinkwater
My range rover seems to be letting water in to the drivers side footwells only when driving in wet weather... any ideas?
Post #342271 Thu May 03 2012 8:38am
Supacat
After water ingress issues with previous Discos, I'd never spec a car with a sunroof again - especially anything out of Lode Lane.
Post #342277 Thu May 03 2012 9:11am
mse
I was just going to say that - why ruin a perfectly good roof?! Mike
2014 Facelift Discovery
Post #342408 Thu May 03 2012 6:31pm
