![]() | Home > Maintenance & Modifications > Spacers |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
10/15mm spacers= alot of cleaning
dazzagt Member Since: 07 Jul 2011 Location: London / Wokingham Posts: 231 ![]() ![]() ![]() |
Interesting ![]() Not fussed on the extra cleaning ![]() ![]() ![]() 997 GT3 - X6 35d |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
I've just ordered 6mm spacers to allow wider tyres (285/55R20s), however, I'm not sure these will fit due to the hubcentric fitting of the OEM RRS rims as the cone on the hub may not locate in the rim due to the bevelling on it.
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
Im not convinced they are needed mate i quite like the overall stance of the RRS, i reckon it could look a tad silly when in normal driving height etc |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
Spacers are a poor engineering bodge - why not do it right and get wider wheels or wheels with a different offset?
kahndesign Member Since: 17 Mar 2011 Location: Bradford Posts: 484 ![]() |
pm'd you darren but as already said, you would need hubcentric ones also the other problem that you have is that the Sport uses wheel nuts and not bolts so by spacing the wheels you will shorten the amount of thread you have left for the nut to screw on to.
Cheers Martin, not seen your PM yet.. would always use hubcentric anyway, the KW ones i used on my CSL and a high end german manufacturer for all the others I used longer bolts and lockers to ensure I had the correct thread. Did 3+ years ( 3 trips a year to the ring ) with approx 40/50 laps per weekend, plus heavy track work throughout my race season, as I used my road car before practice / test day to get to grips with the circuit .. so it was used hard both road and track running spacers throughout its 4/5 years of ownership with no issues whatsoever .. so not sure why people are so concerned with using them on this forum, especially as hardly anyone has actually used them.. hence the Q originally as new to RRS tuning and tweaking ![]() Will see what options you can throw at me with a lower offset wheels !! ![]() 997 GT3 - X6 35d |
Si-W85 Member Since: 22 Mar 2015 Location: Huddersfield Posts: 109 ![]() |
Anybody actually fitted spacers and can comment on how they get on with them and what size you went for? |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
i have 30mm lol fitted to my rear wheels and had no problams yet but if i was to put somemore on they would be 20mm |
Ok thanks for the pics nice motor |
It depends on width of your wheels. I only need them on my rears as fronts look ok |
Looking good Dave :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 997 GT3 - X6 35d |
