Home > Maintenance & Modifications > Spacers
dazzagt
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
Spacers
Chaps, not seen or regularly see posted any info on spacers for the RRS, on nearly all my M3's and the CSL I've run them, mainly for better stability and turn in ( as I did a lot of track days ) and the wider track gives a much meatier and aggressive stance.
Now for the RRS I see some companies do them H&R etc, but wondered if anyone has run or is running them, and has any thoughts, good or bad ?
Obviously Im not intending on tracking the RRS Mr. Green , but with say 10/15mm all round it will fill out the arches nicely and may be a bit more composed on turn in on the road, so could be a nice little upgrade.
Thoughts ?
D RRS S/C, Factory Fitted Full HST kit, 22" Overfinch SS, Carbon Vents & Grill .. - FOR SALE - PM me for details
997 GT3 - X6 35d
Post #329102 Sun Jan 22 2012 9:06am
shepp
10/15mm spacers= alot of cleaning
Mine gets muck all over, on standard. extra 15 mm would mean a very mucky motor.
On a serious note, alot of insurance companies refuse to insure spacers even ones that insure mods.
Post #329105 Sun Jan 22 2012 9:25am
dazzagt
Interesting Thumbs Up Thanks for that, I've always been from the ' car came with it ' mindset, and never had any issues ..not sure what difference spacers would make other than improving cornering and stability..
Not fussed on the extra cleaning Laughing ... when you have John round the corner Whistle Mr. Green RRS S/C, Factory Fitted Full HST kit, 22" Overfinch SS, Carbon Vents & Grill .. - FOR SALE - PM me for details
997 GT3 - X6 35d
Post #329106 Sun Jan 22 2012 9:31am
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
I've just ordered 6mm spacers to allow wider tyres (285/55R20s), however, I'm not sure these will fit due to the hubcentric fitting of the OEM RRS rims as the cone on the hub may not locate in the rim due to the bevelling on it.
If you're going for 10/15mm, it would need to be 15+mm to clear the hub cone and allow the spacer to have its own hubcentric cone for locating the rim, to prevent vibrations due to lack of location resulting from the 'flat' wheel lugs.
I'll let you know how it goes... if it works I have a good custom tool shop that can make spacers to your exact specs.
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #329129 Sun Jan 22 2012 1:47pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Re: Spacers
Thoughts ?
D
Im not convinced they are needed mate i quite like the overall stance of the RRS, i reckon it could look a tad silly when in normal driving height etc
Post #329131 Sun Jan 22 2012 1:54pm
Supacat
Spacers are a poor engineering bodge - why not do it right and get wider wheels or wheels with a different offset?
There's quite some forces going through the hubs & moving the load paths by 10 to 15mm without knowing the results seems like russian roulette.
Post #329133 Sun Jan 22 2012 2:29pm
kahndesign
pm'd you darren but as already said, you would need hubcentric ones also the other problem that you have is that the Sport uses wheel nuts and not bolts so by spacing the wheels you will shorten the amount of thread you have left for the nut to screw on to.
get at me as i have some wheels available with a lower offset to stance the car out a bit.
martin
Post #329236 Mon Jan 23 2012 4:00pm
dazzagt
martin
Cheers Martin, not seen your PM yet.. would always use hubcentric anyway, the KW ones i used on my CSL and a high end german manufacturer for all the others I used longer bolts and lockers to ensure I had the correct thread.
Did 3+ years ( 3 trips a year to the ring ) with approx 40/50 laps per weekend, plus heavy track work throughout my race season, as I used my road car before practice / test day to get to grips with the circuit .. so it was used hard both road and track running spacers throughout its 4/5 years of ownership with no issues whatsoever .. so not sure why people are so concerned with using them on this forum, especially as hardly anyone has actually used them.. hence the Q originally as new to RRS tuning and tweaking Smile
Will see what options you can throw at me with a lower offset wheels !! Mr. Green RRS S/C, Factory Fitted Full HST kit, 22" Overfinch SS, Carbon Vents & Grill .. - FOR SALE - PM me for details
997 GT3 - X6 35d
Post #329238 Mon Jan 23 2012 4:38pm
Si-W85
Anybody actually fitted spacers and can comment on how they get on with them and what size you went for?
Post #457553 Sun Mar 29 2015 7:47pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
i have 30mm lol fitted to my rear wheels and had no problams yet but if i was to put somemore on they would be 20mm Thumbs Up
Post #457756 Tue Mar 31 2015 6:27am
cossiedave
Post #457757 Tue Mar 31 2015 6:30am
Si-W85
Ok thanks for the pics nice motor Thumbs Up 20mm on all four you think? Cheers
Post #457769 Tue Mar 31 2015 10:48am
cossiedave
It depends on width of your wheels. I only need them on my rears as fronts look ok
Post #457773 Tue Mar 31 2015 11:20am
dazzagt
Looking good Dave :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  RRS S/C, Factory Fitted Full HST kit, 22" Overfinch SS, Carbon Vents & Grill .. - FOR SALE - PM me for details
997 GT3 - X6 35d
Post #463934 Sat Jun 06 2015 11:07pm
