Home > General > Suspension
george1980
United Kingdom 2013 Range Rover Sport 4.4 V8 Autobiography Santorini Black
Suspension
Hello,
First proper post
I have a2011 hse sport and love it apart from one thing, ride is great on smooth and bumpy roads but shock absortion isn't the best I've been in, when doing a demo we also tried the disc 4 which was a more comfortable ride which is the ride we prefered but prefered everything else about the sport, just demo'd the range rover and the ride is fantastic compared to sport , i know its a long shot but has anyone had the dynamics adjusted on the sport? or even fitted disco suspension? I am aware that ride hieght can be adjusted but its a softer ride I'd like,
Any sugestions would be appreciated
Thanks George
Post #327337 Sun Jan 08 2012 8:56pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
could having Adaptive Dynamics engaged causes this effect Question ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #327345 Sun Jan 08 2012 9:46pm
SONYBOY
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
still have a knocking sound when driving on uneven roads,and a dam noise in boot area? any one else have any noise from there rear boot ares? Sad 2007 COOLRRS
Post #327348 Sun Jan 08 2012 10:40pm
george1980
Mine did that , Tighten the main tail gate by adjusting the ring the lid pulls down on, this pulls the boot lid tighter on the seals if its the same as I experianced. Also a can of silicone spray of boot wax on seals including the doors gets rid of any sqeeks you might get after there is more presure on the seals
Post #327354 Sun Jan 08 2012 11:03pm
peanutbob
2008 Range Rover Sport TDV8 HSE Zermatt Silver
RRS ride on much lower profile tyres, whereas Discos and FFRRs are often on 55 profile tyres which make a huge difference to the ride. I have changed to 45 profile on 20" rims against 40 profile which has produced a ride quality that is nearly as good as the D3 I had before.
Then, under warranty, having both arc bars replaced plus drop links, followed by several weeks later having these re-torqued stopped the suspension knocks front and rear. Fingers crossed, 8000 miles later all remains quiet underneath, and the new set up has produced a ride quality that is close to Disco spec!
Post #327361 Sun Jan 08 2012 11:17pm
george1980
Thanks for that, I'm currently looking at some 19 inch wheels on ebay which I was going to fit some 55 profile tyres on, I dont get any Knocking though, suspension is perfect for rattles just a little harder than 'd like, its done 16 k know and never had a problem with the car at all, I'd fit 18's on it but from what i've read they won't fit over the calipers?
Post #327379 Mon Jan 09 2012 6:37am
Supacat
Out of interest, what tyres did you select?
Post #327398 Mon Jan 09 2012 9:22am
rrsboy
can you tell us which dealer? ============
Post #327401 Mon Jan 09 2012 9:40am
george1980
Are the arc arms and drop lincs simply a replacement as orininal ones or different type/setting
Post #327416 Mon Jan 09 2012 11:00am
