Home > General > brembo brakes
Bear100
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
brembo brakes
do all my2010 hse tdv8 sports come with brembo brakes as standard?
Post #324629 Fri Dec 09 2011 11:23pm
Supacat
I'll stand corrected but I think none of them do. Brembo were standard fitment on earlier years but for MY10 Landrover changed the brakes back to non-branded LR. It would be interesting to know who actually makes them them - it could conceiveably still be Brembo - just that they are not branded as a Brembo product.
Post #324658 Sat Dec 10 2011 2:44pm
If i remember correctly, all TDV8's and S/C models came with Brembo brakes, LR changed them on the 3.0L TDV6 to none branded brakes as you say supacat, however the S/C still comes with Brembo's
Post #324685 Sat Dec 10 2011 8:17pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
front and rear on the 10MY cars as well
Post #324690 Sat Dec 10 2011 9:27pm
Post #324691 Sat Dec 10 2011 9:31pm
rr5port
2010 Range Rover Sport TDV8 HSE Santorini Black
The 2010 Range Rover Sport is equipped with a new braking system which has
been comprehensively updated to provide enhanced stopping power and
improved driver feel.
The brakes for the diesel and naturally aspirated vehicles are modelled on the
4-piston opposed caliper performance system from the outgoing
Supercharged unit. The updated system employs 360mm ventilated front
discs with new twin piston sliding calipers made from cast-iron for enhanced
pedal feel. The rear features 350mm ventilated discs with lightweight
aluminium single piston sliding calipers.
The braking system for the Supercharged model has been developed in
conjunction with performance brake specialists Brembo�. This system
employs 380mm ventilated front discs with unique lightweight aluminium sixpiston
opposed action monoblock calipers. 365mm ventilated discs with
single piston sliding calipers are fitted at the rear.
Big Cry My TDV8 wants its Brembos back Embarassed 10 RRS HSE TDV8 --- No complaints so far
57 RRS HSE TDV8 --- Great Car. Heated Windscreen & Brake Module both replaced under warranty.
10 months great driving, before I couldn't do without the new interior
Post #324834 Mon Dec 12 2011 1:03pm
x5pea
Ive got a the new tdv6 and must admit i miss the brembos from my S/C, so much so I'm considering picking a set up.
Out of interest anyone know if there is any upgrade to the brakes over the std models when choosing a TDV6 Autobiography ?
Post #324836 Mon Dec 12 2011 1:06pm
rr5port
I'd change them in a heart beat, except for 2 good reasons, COST & WARRANTY Big Cry
AB has same setup as per engine spec, so only S/C get Brembos 10 RRS HSE TDV8 --- No complaints so far
Post #324838 Mon Dec 12 2011 1:13pm
In a word no Big Cry
Post #324839 Mon Dec 12 2011 1:13pm
x5pea
Be interested to see if the servo ect were all the same on both the TDV6 & S/C. Ive done quite a few brake upgrades on track and show toys and its surprising what the std servo facilitates.
Post #324850 Mon Dec 12 2011 2:24pm
JUCOTT01
I replaced my calipers on my 2011 TDV6 and replaced them with 2010 supercharger brembo 6 pots straight fit just needed to replace the discs with 380mm
Got them powder coated "Brembo Red" at the Brake caliper specialist for �135
Razz Razz
 RRS MY11 BALI BLUE OVERFINCH
Post #324889 Mon Dec 12 2011 9:02pm
Bear100
fair play they look the muts nuts Bow down
i have seen them on a few rrs and thought they might have been a standard fit, daft for them to be replaced by land rover, its little things like this that has some sort of appeal to us ageing petrol heads!!
don't think i would go the distance and have then changed tho
Post #324890 Mon Dec 12 2011 9:08pm
JUCOTT01
Here is a before
And after
Post #324904 Tue Dec 13 2011 12:03am
Supacat
They look really good. How much did they cost you and did you leave the rears as standard?
Post #325386 Sat Dec 17 2011 7:27am
Kensta
JUCOTT01 wrote:
Here is a before
And after
Thumbs Up Java black 2006
Post #325387 Sat Dec 17 2011 7:59am
